Question about Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher
  • 4 more comments
  • RachelG Apr 12, 2008
    Our dishwasher will not drain. I have hit the cancel/drain button and it sounds like it's doing something but when you open the door, it's still has lots of standing water at the bottom.
  • Cindy F Apr 21, 2008
    I have the exact same problem.....I push the Cancel/Drain button, but after it finishes the drain cycle, there is still standing water in the bottom of the dishwasher.
  • jc2034 Aug 26, 2008
    Whirlpool dishwasher will not drain. I pushed Cancel button and all it did was hum for 2 minutes...still didn't drain.
  • skylla_6 Sep 06, 2008
    My dishwasher want drain when it finishes the wash cycle but will if you hit the cancel/drain button afterwards. I am thinking electronic panel.
  • tnl76 Sep 09, 2008
    I have a Quiet Partner II that will not drain after a complete cycle. The dishes are clean but water remains after cycle. When I hit cancel/drain it will drain at times but not all the time. Please help.
  • Anonymous May 07, 2009
    it goes through the wash cycle but will not drain, even if I hit "cancel/Drain" it doesn't drain, it makes the nopise like it is, but does not.
I had this problem too & found the discharge hose was clogged. To fix it I had to pull out the diswasher , disconnect the drain hose and blow it out.
Posted on Oct 05, 2008
Dishwasher not draining
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
My maytag dishwasher repeats the cycle over and over
open the door and turn it off that should cancel out the drain cycle
Sep 01, 2014 | Dishwashers
I have a 6mth old Maytag Quiet Partner that will not drain. I took the hose off the drain pipe and hit the Cancel/Drain button and put the hose into a bucket-worked fine. I then re attached the hose to the...
Seeing where it will work when disconnected from drain, i would be looking at the house drain as the problema nd not the dishwasher. You can check these things.
1) a clogged pipe under sink that it connects to
2)do you hava airgap,its a piece that goes on the sink and hasa chrome cover about 2-3 inches tall,if ya have one of those(not all drains do) reomve cap by pulling off and depending on brand of air gap unscrew inner cap or push in the 2 tabs and pull out inner piece to check for a blockage
3)if you dont have airgap is the drin hose under the sink always slooping down? at on point the drain hose should be higher that the level of the peice on the drain it attaches too,with corrogated drain hose its easy to pull it up and attach it under sink so at one point the hose is higher that the drain(disposer) nozzle
Good luck, i hope this helps
Aug 04, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Mar 16, 2011 | Bosch Dishwashers
Bosch dishwasher model shx33a can't figure out how to just drain without running the whole cycle...HELP
usually on the consol in small print it will say press these 2 keys to drain. Read all the lettering on the consol and let me know
May 28, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Whirlpool dishwasher won't start
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Jan 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
if you hit the stop cancel button and you hear a hum then you have a clog. in the pipe somewhere. usually ing the "air gap" in the sink. if you do not hear a hum when you hit the stop cancel button then the drain pump is bad and needs to be replaced.
Nov 27, 2008 | Dishwashers
Water slowly filling cabinet when dishwasher is off.
leaking valve - to check, turn water off and see if it still happens
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher has lights but won't do anything
Jacksonville, did you remove the knock-out for the drain on the disposer? Use a screw driver and punch it out. Let us know if that did the back.
Nov 22, 2006 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher Logo
236 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
