Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
I have a sterling classic scooter I washed it let it dry then went to switch it on and the spanner kept flashing its dry now but the spanner isstill there how can I stop it
  • 103 Answers
SOURCE: charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Posted on Jul 23, 2009
bunnydawg
  • 5158 Answers
SOURCE: manual for sterling elite 4 mobility scooter
i haven't been able to locate a manual online however here is the company website http://www.sterlingscooters.co.uk/index.asp email them or call them they may be able to assist you. keep in mind many companies won't offer support for products bought on ebay.
robert
Posted on Sep 08, 2009
Testimonial: "thanks for the answer so quick il phone them tomorrow"
  • 19 Answers
SOURCE: info neede for mobility scooter
http://www.scootamart.com/mobility/mobility-scooters/heavy-duty-8mph-mobility-scooters/sterling-elite-xs-4-mobility-scooter.html
Posted on Oct 02, 2009
Testimonial: "I had given up hope after mailing several company's asking for the number for the scooter, which was met with no answer, then this morning I cam to mai"
gfreed100
  • 60 Answers
SOURCE: WERE CAN I GET A ( C7-AC2-110)MAIN CONTROLER FROM FOR A STERLING EMERALD
I think i've found it. Go to this website; Click here
http://www.discountscooters.co.uk/extra/pages-productinfo/category-88_90_103/product-1134/scooter-spares-by-make-sunrise-medical-spares-sterling-emerald-sunrise-medical-sterling-emerald-main-controller.html
Posted on Jul 27, 2012
gewiz
  • 1271 Answers
SOURCE: I have a Sterling Micro 3 wheeled scooter. When I turn the throttle off the scooter carries on rolling and does not stop like it used to. Anybody know whats gone on my scooter?
Hi, Okay first of all the throttle pot may not be returning to the central position any-more normally this causes a error condition, a bleeping sound, the other thing is the brake is not working correctly , it be worn or not releasing , Do you hear a click when going forward or backwards ?, Some Sterling's work with the brake disconnected so check the wiring.. remember 24v is applied to the electromagnic brake to release the plates allowing you to move, keep me posted please. Gewiz
Posted on Dec 06, 2012
Max weight carrying capacity -Sterling Pearl scooter
Hello I looked up the specs on this and the max weight for this scooter is 136kg or 300 lbs (give or take a few ounces) you may find this information here:
http://www.sunrisemedical.co.uk/mobility-scooters/sterling/mobility-scooters/pearl
Hope this answers your questions.Have a great day.
Sep 26, 2017 | Health & Beauty
How do I fix a continuous bleeping sound from my Sterling Pearl mobility scooter, even when switched off. The batteryis fully charged.
hi Brian, Normally caused by a short within the controller, the switch circuit is not turning off,
I offer free testing service, you only pay for the return postage..
Also what can happen is the horn switch get water inside so conducts and turns on however turning the scooter off will stop this noise..
Regards
Rob
gewizrepairs.co.uk
Oct 01, 2016 | Health & Beauty
How do i fix a throttle on a sterling sapphire mobility scooter
The Sterling Sapphire is not sold in the USA so, you may want to verify this information with a local technician however; 7 flashes or beeps is commonly a throttle issue. When the problem starts and you have been driving for awhile, ensure the throttle lever is in the stop position, turn off scooter, wait 10 seconds and turn scooter back on. If that does not clear your problem: There should be two set screws (very small) that you can tighten with an allen wrench on the throttle lever. Make sure those are tight.
If this is a continuous problem, you may need a new throttle potentiometer.
Apr 29, 2014 | Health & Beauty
Jul 27, 2012 | Electric Mobility Health & Beauty
I have a sterling diplomat 306 id,
Look at the right hand back corner of the bootlid recess, there is a very small steel spike sticking up which is a switch. Sometimes if the scooter goes over a sharf bump, the lid jumps slightly and the switch lifts momentary and puts the brake on. It thinks the lid has been lifted and goes into charging mode.
Switching the power on and off resets the system until the next sharp bump.
The switch is ajustable, or the bootlid needs to be pushed down harder before locking it.
I had this happen on my Diplomat 408i.
Hope this helps.
Regards,
Paul
Jun 01, 2012 | Health & Beauty
We have just put dads Sterling Classic back together after months standing idle. When we switch the battery charger on it says check but what do we need to check.
Hi. The main thing to check for is that the charger is actually connected to the batteries. If the charger has a 3-pin plug that plugs into the scooter, check that there is no broken wires in the plug. Also check the socket in the scooter with a multi-meter, you should be able to read the battery voltage from the meter.
Most chargers sense the voltage in the batteries, and base the charge rate on this voltage. If the charger is not connected to the batteries when it is turned on, it will drop out and go into a fault mode.
Good luck. Neil.
Jun 26, 2010 | Health & Beauty
It is an awoe 8558. the spanner symbol is flahing
Hi, I have exactly the same problem. Did you ever get a solution to get the door open manually?
Apr 01, 2010 | Whirlpool Washing Machines
Manual for sterling elite 4 mobility scooter
robert
Sep 08, 2009 | Elite Health & Beauty
Charging sterling elite 2001 scooter batteries
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
205 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
