Question about Hotpoint WMA48 Front Load Washer
I have a WMA 48 and it keeps tripping the electric when i put a wash cycle on, although it will complete spin cycle
  • 1,557 Answers
There is a ground leak or pos net leak in the main motor it needs to be looked at by a service agent very dangerous problem dont use it till fixed
Posted on Apr 28, 2010
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Power trips in spin cycle
Pump is leaking water and causing problems. Replace the fault part and clean thoroughly.
Feb 27, 2014 | Samsung Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
Simpson esprite 650 front loader washing machine. Electricity trips on programs b & h wash, can't complete cycle. Spinning and draining cycles OK. Why ? thanks sally
Hi Sally.Now in your posting you mentioned the machine trips the safety switch during the main wash.Is this correct?Does it trip as soon as the barrel stars to turn or a little later.Could you explain what b& h wash is.If the machine spins and drains and fills but trips during the cycle then from working on this model of machine I think the fault is your heating element.Have you tried a cold wash without any temp setting?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Washing Machines
When my hotpoint wma 48 is on a wash cycle water starts seaping through the front door. Gets worse when it goes on to the spin cycle. Please help
Clean the door itself and the door seal. close the door and give the glass bowl a tap at the bottom where it meets the seal with your fist this should do it.If not change the door seal
Jun 11, 2010 | Hotpoint WMA48 Front Load Washer
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Whirlpool duet sport washer powering off during spin cycle
I had this problem with new duet sport washing machine. Service was out to fix under warranty (4 trips!) replacing water sensor and boards. Finally checked outlet and was told no neutral. ?? Charged us for that visit since not covered. Plugged into another outlet and it worked. Had electrician in, replaced original outlet (although saw no sign of bad connection) and washer worked again! Yippee until today when I had the same issues. Tried in another 2 outlets and still shut down after a few minutes (and in those few minutes it never really ran as it should) Went out to get an outlet sensor ($8 at hardware store). Plugged in and found no errors. Started washer again and it did run and completed cycle. Although estimate 1 minute of final spin cycle took almost 25 minutes (on QUICK wash no less!) Will have to monitor. See if we get lights on outlet sensor next time washer doesn'twork, see what other things in house are running, etc. (although washer on dedicated line). ONLY change since this happenned: We replaced our 30 y.o. electrical box. You'd think this would be better???
Nov 30, 2008 | Washing Machines
Hotpoint WMA 48, tripped house rcd, no lights on and water heating noise.
need to know a little more really but here goes, if you remove the top and the drive belt is still on then it will be as straight forward as the motor brushes at fault they will need replacing as this is a common fault on these machines. hope this helps
Mar 06, 2007 | Hotpoint WMA48 Front Load Washer
Hotpoint WMA48 Front Load Washer Logo
57 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
