Question about Wega Mininova EPU Espresso Machine
Coffee grinder is producing large granules
Coffee machine is not grinding properly.
    President:
  • 1,618 Answers
Adjust grinder to finer, if there are numbers on the adjustment knob, it is still possible to go past 0.
Posted on Apr 27, 2010
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
I have a mazzer luigi coffee grinder on which set is the best coffee you get
grinding setting is one simple operation but requires a bit patience:
1 turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest ginding) 2 from that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line 3 grind little amount of coffee only to fill one sector of dosser than test it at your machine(if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way. 4 you test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation) 5 after setting measure the grinded coffee that come out from doser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of doser.
PS: the pump pressure of coffee machine should be from 8 to 10 bar and steam pressure should be from 1.1 to 1.5 bar> depends on type of coffees you use.
Nov 14, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
My grinder just stopped grinding... turned it on, heard a "Chunk" sort of sound and it stopped grinding. Timer works and light comes on but no grinding. I also cannot unscrew the top portion to look and...
  • DIAGNOSIS
  • it can be too tight stringed at burrs
  • some stone or metal part with coffee went between burs
  • IF IT IS AUTOMATIC, it can be one of 2 micro-switches or main relay, in this case you have power but only to middle of way.
SOLUTIONS
  1. Release the burrs, grind one amount coffee with bigger granulation than go back again carefully.
  2. Disassemble the upper burr holder and clean carefully, all coffee and remains put in one plate, inspect with magnet, hand and than put all that in water. (heavy parts fell down fast in water)
  3. Check the switches and relay:
  • Upper micro-switch has an plate and one box where it is( box might be full of coffee or the plate blocked and giving the signal of full doser every time)
  • Lower micro-switch should activate every 6th pull of doser(he is below in mechanism of doser)
  • Relay gets power from micro-switches when they command. even we switch on if the commandsof micro-switch says off than relay will not obey us.
Oct 18, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
What is the correct setting for grinding coffee for expresso
Grinding setting is one simple operation but requires bit patience:
  1. Turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest grinding)
  2. From that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line
  3. Grind little amount of coffee only to fill one sector of dosser than test it at your machine (if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way.
  4. You test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation)
  5. After setting measure the grounded coffee that comes out from dosser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of dosser.
Sep 13, 2010 | Rancilio Rocky SD Grinder without Doser -...
How do i adjust gran throw on a simonelli grinder
Aug 30, 2010 | Nuova Simonelli MCD Electric Grinder
Coffee is not strong enough?
Hi
There are 2 knobs in the bean hopper. Turn the small one to the + then back up 1 click. Turn the large knob to a smaller number, but only when it is grinding. The grind should look like coarse granulated sugar. It takes 3 cycles for the grind to take effect.
Jan 12, 2010 | Gaggia Syncrony Compact Digital Espresso...
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
Calibrate sm 90 coffee grinder burrs
Nov 17, 2009 | Coffee Makers & Espresso Machines
Problem with tamping
Try adjusting the grind to a finer setting also the amount of coffee can be adjusted with the lever in the grinder chamber.
May 06, 2009 | Gaggia Syncrony Compact Coffee...
Our Saeco Vienna deluxe had a couple of problems: the grinder wouldn't stop grinding..coffee all over the place...stopped it cleaned it and it's ok. The other problem is that it takes forever for a small...
What does the coffee produced taste like, is it bitter and watery, is there any creama on the espresso shot. Try adjusting the grind and the coffee level, maybe a little coarser.
Mar 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Wega Mininova EPU Espresso Machine Logo
81 people viewed this question
Top Wega Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
