Question about Craftsman 25cc Gas Line Trimmer
Pull cord won't retract when housing asseembly is put back together. Works just find when not assembled. Any suggestions would be appreciated.
    Problem Solver:
  • 8 Answers
Housing is pressing on recoil sprocket,,,,shim with washers to get clearence. Also check to see if recoil sprocket is seated all the way down aginst the stop on the crankshaft.
Posted on Apr 27, 2010
Poulan lawn mower cord won't retract
New or used unit? If new can you return it ? If not you will need to take the recoil assembly off the engine and rewind the spring. Check inside the recoil assembly to see if the spring is broken or just popped out of place on either end. If it is broken your done. You will need to find a Poulan dealer to get a new spring. If new take it to a Poulan dealer for warrenty replacement. If you want to try to rewind the spring look to see where one end of the spring fits into the housing and the other into the spool. On the edge of the puley should be a notch. Place the rope in the notch and turn the pulley it in the direction needed to wind the spring about 4 or 5 turns. If it now pulls all the rope in you are done.If not put the rope back in the notch and wind the spring tighter till the rope is all pulled in.
Jul 25, 2013 | Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
I replaced the pull cord on an mtd mower. and now it won't rewind the cord?
You have to tension the spring before installing the cord. Remove the cord. Put the recoil assembly in a vise. Prepare the ends of the cord so they can be threaded into place. Spin the pulley in the proper direction until it is tight. Align the hole in the housing with the hole in the pulley. Thread the rope in and knot it and pull tight. Slowly let the spring tension retract the rope. Cut the rope to length, install handle, knot and test.
Gary
Aug 27, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Recoil pulley assembly keeps binding. Rope stays in pulley, but won't retract. Must remove motor housing , loosen 3 pulley hold down guides, & uncock the pulley. spring tension on recoil is fine....
Have you ever replaced the recoil rope, if you had is it a larger rope then the one that came with it? If so, that could be the cause of the binding. I had that difficulty once.
Aug 05, 2011 | Garden
Pull cord is stuck
This happens all the time. To fix it is not to bad. You have to take off housing around where then pull cord is, then when you get to the pull cord pulley, sometimes you can just untangle where cord is. The pull cord is in like a spring housing , this is what retracts it. It is all spring designed to pull and retracted. You will notice that when you take off pulley, there our little tabs that are bent in, that is designed to hold rope pulley in. There is a spring set up behind that. If rope is just tangled or crisscrossed then can carefully untangle and put back together . If not take that whole piece in and they can replace spring that has worn out or jammed. Hope this helps, I had it happen to me on a edger , was not to bad of a home project. Thanks, mike from fixya
Jun 13, 2011 | Garden
Starter cord pulled out of the housing, it
if it's new take it back should have a one year warrenty on it if yo can't get it done for free get back to me so I can help you you may have a damaged windind head.
Apr 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
How do i get the pull cord spring back in on a
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly. HTH
Lou
Nov 22, 2009 | McCulloch Garden
Retractable power cord
JUST LIFT OFF THE TOP HALF. CAREFULLY REACH IN FROM THE LEFT SIDE AND DISCONNECT THE CLEAR PLASTIC HOSE THAT IS ATTACHED TO THE "DIAL" ON TOP OF THE MACHINE. THEN LAY THE TOP HALF OF THE MACHINE TO THE RIGHT. DON'T DISCONNECT ANY WIRES. YOU'LL HAVE TO HAVE A NEW CORD WINDER (LOOK ON E-BAY). THE MOTOR AND CORD WINDER ARE ATTACHED TO EACH OTHER BY WIRES AND CAN BE LIFTED OUT OF THE CANISTER.EVERYTHING YOU DO JUST REMEMBER THAT ALL OF THESE PARTS ARE ATTACHED TO EACH OTHER BY WIRES. THE ONLY WIRES YOU'LL NEED TO DISCONNECT ARE THE ONES ATTACHED TO THE CORD WINDER ASSEMBLY. THEY JUST PULL OFF, NO TOOLS ARE NEEDED.
QUITE FRANKLY THIS IS A ROYAL PAIN AND YOU'LL PROBABLY WISH YOU TOOK IT TO A REPAIR (AERUS/ELECTROLUX) SHOP. IF YOU DECIDE TO DO IT YOUR SELF TAKE PICTURES OF EVERY STEP...'CAUSE YA GOTTA PUT IT ALL BACK TOGETHER.
GOOD LUCK!
Sep 08, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Craftsman 25cc Gas Line Trimmer Logo
319 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
