Question about Frigidaire Refrigerators
We have a frigidaire refrigerator Model FPC1-170tt. How old is it?
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem and also kindly check and confirm the model number of the refrigerator.
Thanks for using FixYa.
Posted on May 05, 2010
Frigidaire refrigerator model ffhs2313lpo
The problem is most likely the=> 241739710 Temperature Control Board That is the electronic display that you said is not working. Sometimes there may be signs that the board is defective but most times there is no physical sign the board is defective, I am here should you need me, Thanks John Tripp Appliance 911
Apr 28, 2014 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
Www frigidaire com
Wire connector loose under door hinge cover or other loose connection, What is the model number? Could be something that I or someone will need the most important part of the refrigerator (Model Number) Try to find if possible, Thanks John Tripp Appliance 911 91641dbb-0105-46fa-be14-a2da26def0cc.jpg
Jan 25, 2014 | Refrigerators
We have a 4 year old frigidaire side by side refrigerator, model phs69ejss0, it has stopped cooling fridge and freezer and there is a 4 flashing in refrigerator temp display area, any idea how to fix?
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper that's bad.
Here is the part to order.
Dec 09, 2012 | Frigidaire Pro PHS69EJSS Stainless Steel...
I have a frigidaire model glhs37ehsb7, serial # 4a92704953. How old is this refrigerator as I got it second hand
It was produced July 2009. The first digit of the serial number tells the year, 9 = 2009, and the next two numbers describe the week during that year it was produced, 27= Week of July 2-7th, 2009.
Aug 21, 2012 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire ref not cold
Refrigerator or freezer is not cold enough check this part:
* Check the temperature setting
* Assure that there is enough room for air flow in the refrigerator or freezer
* Check for air flow restrictions in vents
* Test the temperature control
* Clean the condensor coils
* Check the door seals
* Test the door switch
* Test defrost heater
* Test defrost timer
* Test evaporator fan
* Check for a clogged drain tube
* Check for refrigerant leak
Mar 29, 2010 | Frigidaire PLRU1777DS Stainless Steel...
How old is my refrigerator?
Here is a --->link<--- to download the manual for your unit.
this --->link<--- will allow you the ask Frigidaire what year the unit was manufactured.
hope this helps
clarkco
Feb 17, 2009 | Refrigerators
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My refridgerator keeps cycling on and off. temperature is50 degrees . where do i put r-134 in on high side at? thanks.
Hi katdaddy,
Welcome to fixya,
You said,
Your refrigerator keeps cycling on and off. temperature is50 degrees .
This means either you have a leak that must be detected befrore you re establish freon pressure or your thermostat is bad.
What is the model # and age of the refrigerator?
Sep 28, 2008 | Frigidaire Refrigerators
Frigidaire refrigerator Model # FPD12TF - not a chest freezer
I have not solved the problem I wrote about. I don't have a chest freezer...I have a refrigerator, model number referenced above. I don't want to join anything - I just wanted advice about my 13-year-old refrigerator. Never mind.
Jul 24, 2008 | Frigidaire 12.8 Cu. Ft. Large Chest...
Refrigerators Logo
27 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
