Error code e000747-221b on cannon c3170ir - Office Equipment & Supplies
  • ffree Apr 27, 2010
    how do you check the fuser?
    This is error code from manual
    Guru:
  • 1,049 Answers
E0007 Means the fixing film is off to the side. I think the 221b indicates a problem with the yellow toner.
I would check the fuser, either the film is off to the side or it is torn.
Posted on Apr 27, 2010
  • NA NA
    NA NA Apr 27, 2010
    I believe this is the printer you're using...
    All laser printers pass paper through a fuser, a pair
    of heated rollers. As the paper passes through these rollers, the loose
    toner powder melts, fusing with the fibers in the paper. The fuser then rolls
    the paper to the output tray, and you have your finished page. The fuser in this printer is above the paper tray near where you insert the toner.
    There is a film around these rollers that makes them smooth and holds the magnetic charge necessary to repel the toner onto the page. Without it the fuser would get dirty and your jobs would print black and dusty. The fuser gets very hot, and if it does not regulate the temperature correctly or the paper is pulled wrong from the unit this fixing film can peal up or shift. In the case of the Cannon I believe you have multiple colors of toner, yellow, magenta, and cyan. To do color properly on this printer the paper is run through each of these toner drums and then re-run through the fuser.
    The e0007xx errors all relate to the fuser and the 221b error gives you a general idea at what point to look and at what stage the process failed. If you have not had extensive experience with printer repair, you may not want to address these issues with the fuser, especially should the fuser need to be replaced.
    It is not a part that pulls freely from the printer; you would have to take the printer apart.
Cannon ir2200/ir3300 error code E000051-0000 HOW TO CLEAR IT
To help you troubleshoot the error and clear it, please follow the steps given below:
- Press Additional functions button.
- Press Function.
- Error (choice).
- Error code choice (wait).
- Press Reset button and (wait)
- Right power supply will turn off.
- Right power supply will turn on.
GuruAid.com
Jul 13, 2016 | Cannon Office Equipment & Supplies
Is cannon ir 2200 the shows me error E000051-0000. How can restore it
clearing error code E000051-0000 in canon IR2200
Try to reset the printer follow this stepTo reset the error
1. Additional functions (push)
2. Function (choice)
3. Error (choice)
4. Error code choice (wait)
5. Reset (push)
6. Right power supply off
7. Right power supply on
Oct 24, 2015 | Cannon Office Equipment & Supplies
E000532 0001 on cannon ir c5030
This is normally a finisher error code, normally the stapler shift error, depending what sub code after the 532 code display, remove finisher to verified that the code goes away.
Feb 05, 2013 | Cannon Office Equipment & Supplies
Cannon ir c3180i printer prompting e000021-0003
This error code means that the develop unit wont rotate, although I have also had this error code when the drum unit wasn't replaced, did it tell you to replace the photoconductor?
May 02, 2012 | Cannon Office Equipment & Supplies
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
Cannon mp150 printer error
sorry, i don`t actually know but i think you should just use genuine catridges
May 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error code E002 cannon 6612 photocopier
this is a canon generic error code that points that the fixing/fusing heaters or sensor has a problem try to swtch off & on the unit, check the ac power supply maybe its not stable, if the problem persist.you have to call your service provider regarding this.
Jul 04, 2009 | Canon Office Equipment & Supplies
Cannon 6612
just go inot service mode and clear the error code
P8 error code on cannon mp260 cannot get to print
The 8 error code just means that the ink absorber is full and needs to be replaced. Power cycling will not help this problem. You need to replace the absorber and reset the counter
http://erkinson.altervista.org/stampanti-canon-codice-errore-lampeggi-led/
Jun 10, 2009 | Canon Office Equipment & Supplies
156 people viewed this question
jasbo
jasbo
