Question about Kodak 5500 ALL-IN-ONE PRINTER
Having a problem with the paper loading. It is
Having a problem with the paper loading. It is consitently jamming - HELP!!!
  • 4,041 Answers
Hello there You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
Repeated paper jam
Paper maybe stuck together by excess humidity or static before loading into tray try 'whirring' the paper set you are going to use.or warm the paper -light bulb will do
Sep 26, 2013 | HEWLETT-PACKARD LASERJET PRO P1606DN...
Media jam tray 1
Here are a couple of links from the Konica website which provide somes illustrated instructions:
Media Jam Tray 1; Paper Pickup Roller replacement instructions.
Clearing Media Jams
Replacing the pickup rollers seems like a drastic first step. I would check to make sure that the paper being used is suitable for this printer and it is in good consition. You might try a different paper to see if it makes a difference.
Good luck in resolving your issue.
Dec 30, 2010 | Konica Minolta magicolor 2430 DL Laser...
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Hi having this printer error. Hope you can
Fuser Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
Gerrit Jan
Nov 05, 2009 | Lexmark C534N Printer
I am having trouble loading paper into my Canon MP190 Printer?
Try loading less paper AND try this trick:
Holde the stack of paper you are going to load with both hands... grip tight with the right hand and "bend" the paper like an arch. Then grip tight with the left hand, loosed grip with right, and "bend" the paper like a valley. Repeat this a few times to quickly seperate the individual pages so they don't stick together and thus jam in the printer!
Hope this helps!
-- RT
Sep 01, 2009 | Canon PIXMA MP190 All-In-One InkJet...
My paper jams 1815dn all in one
I have encountered this phenomena before on other and better brands ( nebver buy dell anything!)
having said thyat perhaps it is the grade or brand of paper you are using, some printers even inkjets cannot handle sime grades of paper. So try to get different paper loaded and see if that fixes it
Jun 23, 2009 | Dell 1815dn All-In-One Laser Printer
Paper jam
I have also had paper jams with the lex x1240, I rectified this as best as I could by using a q-tip dip in rubbing Alchohol, and clean both sets of rollers good and be vey careful when loading paper. Also try one sheet at a time if you have not already, if it doesn't do it with 1 or 2 sheets in the tray, try loading less paper, or load until the problem re-occours and you may only be able to load 25 pages in autofeed instead of 50. I know that if it does work that way you may want to pursue any warrantie actions you have, But You are definately not the first to experience this. I am sorry you are having problems I hope this can help, It's usually just to much paper loaded that cause this or dirty rollers.
Apr 08, 2009 | Lexmark X340n All-In-One Laser Printer
Canon PRIXMA iP2600 Printer keeps jamming when loading paper.
You have a small oyster cracker lodged in the paper path. Turn it over and shake it out good. see what falls out. OK it may not be an oyster cracker but that's what fell out of mine and now it works.
Nov 16, 2008 | Office Equipment & Supplies
Brother printer jams all the time
Be sure the paper tray is not over full and maybe even fan the paper before loading. Check all the corners that hold the paper as they are usually adjustable for different paper sizes and sometimes move or become unattached. The paper must lay flat and snugly in all places in the tray to load properly.
Mar 28, 2007 | Brother MFC 420CN All-In-One InkJet...
Kodak 5500 ALL-IN-ONE PRINTER Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
