Question about Compaq Computers & Internet
I just inserted a dis into my laptop and now it won,t release.keeps getting error,won,t eject .Is there anyway I can remove it without taking it to get repaired?
    Genius:
  • 1,552 Answers
Take a Norwegian paper-clip, and straighten one end.
Push that end into the small hole in the faceplate of the CD-ROM.
Push until you feel resistance, then gently push 1 more centimeter.
That should "unlock" the drawer, and you can "manually" open the drive the remaining 95%.
Posted on Dec 28, 2014
Bios password
dis assemble your laptop and remove cell. then start your laptop without cell. after clearing p/word, insert the cell.
Sep 26, 2013 | Dell Inspiron 630M Notebook
Disk won't eject
Normally all readers have a mechanical system that can be accessed from the front or the back of the reader to open using a small tool. Normally it's a little hole (like on smartphones) where you can insert a metal piece and push on it to eject the drawer.
May 30, 2017 | LG RHT599H 500GB HDD DVD Recorder with...
Can't figure out how to insert SD card in Lenovo thinkpad T420
Typically there is an spring-load eject on laptop card readers. If you inserted it correctly, then you can gently push the card in about 1/4 inch, it will click, and it will eject when you release it.
Nov 28, 2011 | Lenovo ThinkPad T420 Notebook
My dell studio 1535 keeps ejecting any disk i try to insert. When I boot up the system the drive sounds like its ejecting about 4 times.
It is likely you will have to replace it. When you boot up tap f12 while the bios is loading and select diagnostics to see if you can get a error from those tests.
Aug 02, 2011 | Dell Studio 15 Laptop
I put pictures in the cd but now it won't eject. It dot stuck inside. I could not eject even if I clicl computer then click eject, it won't eject
Power off the notebook, remove power cable and battery. Then try inserting a paper clip into the small hold in the CD drive to force eject the tray. Make sure you have powered off device and removed battery before you attempt.
Jul 10, 2011 | Fujitsu LifeBookS6120 Notebook
My daughter put the blue ray DVD into the Toshiba 14DLV75 instead of the regular DVD and now it won't eject it. It just keeps spinning like it wants to eject, but won't. How can I get it out?
Hello
Just switch OFF the set by its front panel power control switch, and then switch it On and press the eject button without any delay. Sometimes the tray will eject, and try to close. If so switch OFF the front panel power switch, while it is out, and take away the blu-ray disc. the switch it On. All will be ok then.
May 21, 2011 | Toshiba 14DLV75 14 in. TV/DVD Combo
I have a 2005 Ford Focus-the cd player-which is only has 1 cd slot, will not eject the cd that is in it-it starts clicking and then I get an error message saying there is no cd in there. How do I get the...
First try this,use a old cd,press and hold eject,try to insert gently under stuck cd
DO NOT PUSH FULLY IN,just lift stuck cd slightly
Keep trying this usually clicks release micro switch and works on all single cd players
If this does not work you could remove unit, and get your local auto electrician to check it out
Go to fitaudio.com for removal details,which is quite easy to remove
Feb 07, 2011 | 2005 Ford Focus
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
I got a cd stuck in the cd/dvd drive for my gateway laptop- i dont know the model. tried to hit eject button and ejecting through computor and it will not open. what do i do?
All CDs & DVDs have a tiny hole on the drive tray.
Get a paper clip, straighten the paper clip and insert it into this hole and push the paper clip in gently, the tray will release and pop out, then you can remove your disc.
You can do this without the laptop being powered up or powered down.
Feb 21, 2009 | Gateway M305CRV Notebook
Games eject
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Aug 16, 2008 | Nintendo Wii Console
Computers & Internet Logo
217 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
