Question about Compaq Presario M2000 Notebook
Cant play my audio cds
Hi ..pls help me out on my compaq presario m2000...the problem is that my dvd/cd drive...I can play DVD's but I CAN NOT PLAY MY AUDIO CD's!!! what wrong with my comp?
    Sergeant:
  • 349 Answers
Go to this site http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=au&dlc=en&product=433559&lang=en and download the firmware update for the drive, this may help.
good luck
Terry
Posted on Mar 25, 2008
SOURCE:
Did a system restore of compaq presario 5000 computer. cd/dvd player will not play gaming cds
See if it would play regular cd, then see if it would play dvd's. The reason is because most gaming cd now and days are dvd's and maybe your dvd-rom has a driver issue or the laser head isn't reading it. So try that first, then see if the drivers for the cd/dvd rom is working properly in the device manager. It may need a dvd coded software, try installing like powerdvd or something. If it still ain't working, and it can't play dvd's then your cd-drive could be history
Jan 30, 2011 | Compaq Presario 5000 PC Desktop
My presario 2100 plays audio cd's but when i try to play a dvd i get "no disc inserted" any ideas?
Hello, maybe you've only got a cd drive fitted in your Presario. Check the logo on the drive door and see if it mentions DVD Regards, nicam49
Jan 17, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
I have a dvd/cd SD-R6252 unit in my r3000 compaq presario. I've burned CDa but cannot burn a DVD. I think I know the answer but I want to be sure is this unit capable of burning DVDs?
Hi, well ur DVD\CDRW drive is a combo drive. It can play CDs\DVDs but burns only CDs as it's NOT a DVDrw @ the same time. It won't burn a DVD.
.... In future I propose u either to replace the drive by a DVDRW or u may buy an external slim dvdrw if u want to keep ur existing drive as well. 2nd solution is best BTW.
Feb 08, 2010 | Compaq Presario R3000 Notebook
My cd drive on my compaq desktop plays cd's fine but will not play dvd's.what can i do it's a windows xp home
You can only play CDs on a CD drive. In order to play DVDs you need a DVD drive. A DVD drive can play both CDs & DVDs.
Hope this info helped you. Good Luck! :-)
Jan 30, 2010 | E-Machines T3256 PC Desktop
Compaq presario 700us will play cds wont play dvds
Try to put your laptop always on flat surface. Uneven base gives angle to the already tiny clearance space for the disc. Could be that the DVD disc run coz its finer, it will spin much slower than CD disc.
Hope i give you some good observation.
Mar 29, 2009 | HP Compaq Presario 700, 700A, 700AP,...
Nero burning on cd writer
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Oct 08, 2008 | Compaq Presario 1200,1600 (297657-001)...
Compaq m2000 boot problem
i suggest you go to bios setup and restor the default if it continues try replacing a diff hard drive or dvd drive drive thats not the one u r using rigght now and i think the problem will be resolved cos i had a similar problem with presario c500 what i did was change the dvd drive n it work well.
hope this helps
thank u for using fixya
May 27, 2008 | Compaq Presario M2000 Notebook
DVD WONT PLAY IN LAPTOP BUT I CAN BURN AND PLAY AUDIO C'DS. I HAVE A COMPAQ PRESARIO V2000. WHEN I INSERTED DVD IT SAYS NO DVD INSERTED I CLEANED THE PLAYER AND STILL DOESN'T WORK CAN ANYONE HELP
Hi damonabrown your laptop should play dvd's even if it can't burn them
as you have cleaned the drive there is not much else you can do ,as it still play's cd's,
data on a dvd is packed much closer as it hold about 6 times the data of a cd, and can fail much easier, it looks like a new drive will be needed soon.
good luck
Terry
Mar 29, 2008 | Computers & Internet
CD/DVD intermitent audio
CD's and DVD's has different speeds try to check your dvd player/rom if it is compatible with your cd/dvd disk. Some dvd players are sensitive it will not play perfectly if your cd's are scratched. try to use new cd's. It might work.
Jan 20, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario M2000 Notebook Logo
78 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
