Question about Zebra 105SL Thermal Label Printer
Increasing Speed on Zebra 105sl
Using a Zebra 105SL & Loftware LLM-WIN 9.5.0.0, how can I speed up the printer?
  • araupp Apr 27, 2010
    Yes, print speed.
    Thanks, but I press and it does nothing. I can't find the Label & Setup or Label Options tabs.
    Someone in our group printed to our machine and it ran fast until we had to power it off, which must have reset something.
    I found the command in the Design app. rather than the Print app. I will test that and see if it helps.
    Scholar:
  • 97 Answers
If you are refering to print speed, from the label format, press F5 to bring up the LABEL & SETUP PROPERTIES. Click on LABEL OPTIONS and print speed will be the first choice.
If you are refering to how fast data is sent to the printer, then that depends on the connection to the PC and whether you are using true-type fonts or not.
Hope that helps !
Posted on Apr 27, 2010
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
How to install a zebra 105sl printer
Install? Well that could mean a lot of different things. Just plug it up and run the ribbon and labels through their correct paths. I don't know anything about your network. (If you even need to set it up that way.) You can just connect it to the back of your PC. Follow this link. This will tell you all about the specifications of the 105SL. Not really your connections though....... http://www.intermeccorp.com/pdf/105SLusersguide.pdf
Jul 09, 2010 | Zebra 105SL Thermal Label Printer
Increase Speed on Zebra 105SL
In the driver there are settings for print speed, you will aslo need to access the menu on the printer and set the speed
Apr 27, 2010 | Zebra Eltron TLP 2844 Thermal Label...
I am trying to change the printing speed from 2 ips to 5 ips but it does not retain the change. I have selected to permanently change it and also tried changing it using my browser but it will not change.
If you change the speed setting on the printer, print a label, and the speed setting reverts to a different setting then the print speed is being changed from the printer driver.
Hope that helps !
Apr 07, 2010 | Zebra 105SL Thermal Label Printer
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
New 105sl printer isn't getting data
What kind of serial cable are you using? Null modem? Also you could try a lower speed
Apr 08, 2009 | Zebra 105SL Thermal Label Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
240 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
