Question about Mitsubishi HS-U775 S-VHS VCR
Vcr My tv doesnt have the right hookups to use my xbox so i hooked up the vcr to it and plugged the xbox video cords into the vcr but now i dont know how to actually make it appear on the tv screen...i can get videos to play but i can get the xbox to play on it...any suggestions?
    Problem Solver:
  • 13 Answers
You will have to tune the TV to the VCR output channel, which it sounds like you are already doing if you can watch videos. Then you need to set the VCR tunert to the correct input channel, probably something like line 1 or Aux or something like that. Probably the easiest way to find it will be to turn everything on and then just scroll through the channels on the VCR until you see what you are looking for.
Posted on May 11, 2009
How do i hookup playstation 2 to vcr with dishnetwork
you dont hook it up to your VCR you normally hook it up to your TV with the 3 colored plugs(Red, Yellow, and White)
Nov 15, 2009 | Sony PlayStation 2 (PS2) Console
How do i hookup vcr to tv
The best way to hook up your VCR is to use the AV jacks (Red, White, and yellow). Plug into AV1 or Video 1 on the back of the TV. Then, plug into Red, White, and Yellow output jack on the back of the VCR. After everything is hooked up, turn your TV channel to AV1 or Video 1 to watch from the VCR.
To record, you'll have to plug your cable box or satellite box to the AV inputs ( Red, White, and Yellow) in the back of the VCR. ( The only thing is it wouldn't be in HD )
Nov 04, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
I have an apex dvd vcr tv the vcr doesnt work vcr doesnt work how
Video out on tv ? If yes just standard rca cables and vcr in video input mode. If no then you`re out of luck.
Nov 03, 2009 | Apex Digital AT2002S 20" TV
Hooking up my x-box 360 through Direct TV
Ok i had it installed today too....i already had it so i have experience with it....get a vcr....in th eback there should be some ports for AV cables hook that up and get one of those cords that look like the direct tv cords and put that in you VCR out to tv...and screw it in with your hands in your tv.....when you have your VCR on the direct tv wont show and if your direct tv is on when your xbox and VCR are on it still wont so turn off the VCR to get direct tv back again.....im 13 and i figured this out...hopefully this helps a bit
Sep 26, 2009 | Microsoft Xbox 360 Console
My akai receiver to my vcr
hi my name is mark, if you have cables. first unplug the power cords to the vcr and the receiver. on the back of the vcr there will an input and an output audio and video connectors. if your vcr does not have them you will need a new vcr that does. if you just want sound, find the Output connectors. there will two. they will be idenified as Audio OUT. plug one end of the red plug into the one labeled Audio R OUT, then the white in the one labeled Audio L OUT. if you are connecting the video up connect the yellow plug to the connector labeled Video OUT. the other ends connect to the receiver, on the back of the reciever find connectors labeled vcr or dvd AUDIO IN. then connect the red plug to the connector labeled R IN and the white plug to the connector labeled L IN.if you are just hooking up sound you done. to hook up video find vcr dvd Video IN and connect the yellow plug to the Video IN. on reciever. if you want the reciever to switch the TV you also need to run a yellow video cable from Video Out from receiver to Video IN on back of TV. when finished plug in vcr and receiver. select dvd or vcr on receiver to listen ot vcr on the receiver i dont know what model you have or it features i hope this helps thanks for your question.
Mar 17, 2009 | Akai 42 in. LCD TV
Sanyo VCR
get a 2 A/V cords (yellow, white, and red plugs). Plug between the Satellites "video out" jacks and the VCR's "input" jacks. Connect the second cords between the VCR's "video out" jacks and the TV's "video in" jacks. Make sure the VCR is set to the input that you plugged the satellite cords into and make sure the TV is set to the input that you plugged the VCR's cords into.
And then you're done. To record, set satellite to channel desired, set VCR to record on the video input (instead of a channel number) and you're good to go.
Sep 08, 2008 | Sanyo VWM-800 VHS VCR
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
I need to know how to hook up an X-Box
Here are some really helpful link some with diagrams
http://www.xbox.com/en-US/support/systemsetup/xbox/console/connecttotv-vcr.htm
http://www.monstercable.com/monstergame/utilities/hookup/xbox_hookup.pdf
Hope these are helpful. The main thing that you want to do is make sure that you hookup the audio/video cables 3 male connectors into the an input on your TV and of course plug in the power cable for your xbox.
Mar 19, 2008 | Video Game Consoles & Games
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
Mitsubishi HS-U775 S-VHS VCR Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
