Question about Dell Inkjet 720 Printer
I installed a 'new' black cartridge. The "Install Print Cartridge" window is open and ask which cartridge I installed? I make my selection and the 'next' window will not highlight to allow me to go on. Nor can I cancel the window. I have closed down my computer, unplugged the printer and nothing seems to help.
  • osr4 Apr 27, 2010
    The solution may have been helpful. I do not have another cartridge at this moment to switch to. I will let you know once I install a different cartridge.
    Genius:
  • 1,043 Answers
There is a problem with the cartridge that you installed in the printer. The cartridges have a small chip on them for security purposes and the chip may be defective. What you need to do is to contact the people who sold you the cartridge and have them replace it for you. Once a proper functioning cartridge is installed then you will be able to continue on to the next screen in the installation process.
Posted on Apr 27, 2010
Why is my black ink not printing
Hi Colleen,
Try this > open a document (from the computer) and select print from the menu,
- In the print screen window select 'properties' Or 'Preferences' or 'Properties'
- In the next window click 'maintenance'
- In the next window there will be many options to clean, align, nozzle check etc... , there click 'Ink cartridge settings'.
- A small windows opens, there select black only. See the image
- try printing, if it fails to print, just return the cartridge to the shop and get a genuine branded one. (dont forget to change the 'ink cartridge settings to normal to 'both black and color')
Hope this help, if you are not able to fix it still, then better come to chat here , thanks! 10_22_2011_5_46_32_am.jpg
Oct 22, 2011 | HP Photosmart C6380 All-In-One InkJet...
HP6988 printer skips lines and only prints bottom half of black lines. Installed new black cartridge, printed test page. Still no change.
Most deskjets include a maintenance section. Open this printer in PRINTERS on Control Panel (assuming Windows). right click on the printer and select properties. You will have to look for the maintenance section. There you should find an option to "clean heads". You may need to do this several times if never done before. After each cleaning, print a test pattern. Hope this helps.
Mar 31, 2011 | HP DeskJet 6988 Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
How to install ink cartridg
  1. Make sure the All-In-One is on.
  2. Pull the control panel toward you, and then open the cartridge access door.
  3. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy.
  1. Pull the old cartridges toward you, and then lift them out. Store them in an air tight container or dispose of them.
  2. If you are installing new cartridges, remove the sticker and transparent tape from the bottom of the cartridges.
Warning: Do not touch the gold contact area on the cartridges.
  1. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
  2. Push back firmly on the cartridges until they snap securely into place.
  3. Close the cartridge access door, and then close the control panel.
  4. Load paper into the paper support and adjust the paper guide.
  5. Use the buttons on the control panel to answer the questions that appear on the display:
  1. If the color cartridge you installed is new (it has never been used), press Select.
If it is old (it has been used), press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the color cartridge you are using, press Select.
If it is not the number of the color cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. If the black cartridge you installed is new, press Select.
If it is old, press the right arrow button once, and then press Select.
  1. If the part number that appears is the number of the black cartridge you are using, press Select.
If it is not the number of the black cartridge you are using, press the right arrow button until the correct part number appears, and then press Select.
  1. Continue with Aligning the print cartridges to ensure proper installation.
Note: You can also use the Lexmark Solution Center to install the print cartridges. For help, see Using the Lexmark Solution Center.
Oct 28, 2010 | Lexmark X4270 All-In-One InkJet Printer
How do you install cartridge in z82 printer
To install the cartridges, please follow the steps given below:
1. Press "Setup" until "Cartridge" appears on the display.
2. Press the "Right arrow" button until "Change cartridge" appears on the second row of the display.
3. Press "Enter/Select." Now you may install the cartridges in the cartridge carrier.
4. Press "Right arrow" to select the color cartridge type that you installed, once "Left Cartridge?" appears on the display.
5. Press "Enter/Select."
6. Press "Right arrow" to select the black cartridge type that you installed, once "Right Cartridge?" appears in the display.
7. Press "Enter/Select."
An alignment test page should print if "New Cartridge" is selected.
From
Jeethu
Sep 15, 2010 | Lexmark Color Z82 InkJet
THE INSTALL COLOR INK NOTICE KEEPS STAYING ON. EVEN AFTER I KEEP INSTALLING DIFFERENT CARTRIDGES
Go into printer maintenance and chose the Canon printer (assuming you have multiple printers). Once you chose the printer you can then perform maintenance and do cleaning and priming. Essentially when you click install new cartridge the system will essentially prime the printer so that when you print a document it will not have to prime itself. It should prime automatically once you close the lid and install the new cartridge.
Feb 08, 2010 | Canon PIXMA iP90 Mobile Printer
The alignment both vertical and horizontal are off!
Title: How to Install/Change the Print Cartridge Document ID:HO46 Back To Answers Properties 1000 Color Jetprinter 1100 Color Jetprinter 2030 Color Jetprinter 2050 Color Jetprinter 2070 Color Jetprinter 3000 Color Jetprinter 3200 Color Jetprinter 5000 Color Jetprinter 5700 Color Jetprinter 5770 Photo Jetprinter 7000 Color Jetprinter 7200 Color Jetprinter Lexmark X63 Lexmark X73 Lexmark X83 Lexmark X84 Lexmark X85 Mac OS 8.6 Mac OS 9.x.x WinWriter 100 WinWriter 150c Z11 Color Jetprinter Z12 Color Jetprinter Z22 Color Jetprinter Z25 Color Jetprinter Z31 Color Jetprinter Z32 Color Jetprinter Z34 Color Jetprinter Z35 Color Jetprinter Z42 Color Jetprinter Z45 Color Jetprinter Z45se Color Jetprinter Z51 Color Jetprinter Z52 Color Jetprinter Z65 Color JetprinterHow to install or change the print cartridge; Microsoft Windows 95; Microsoft Windows Me; Microsoft Windows 3.1x
Solution Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Dec 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How do I align ink jets?
      3. Click OK.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
is this a pc or mac?
for windows general make sure you folowed these steps:
      3. Click OK.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Cannot print
It seems that another cart is empty. Check all cartridges when printer is off. And yes, you do need the color ones to print in bk.
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Dell Inkjet 720 Printer Logo
63 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
