Question about HP OfficeJet 6110 All-In-One InkJet Printer
After days of back and forth from allign cartridge to paper too narrow, to paper jam, to align cartridge to paper too narrow, to paper jam, maybe one successful print job,and then back to the align cartridge, paper too narrow, to paper jam over and over - have tried, looking at cartridges, check correct number, check for proper attachment, check for paper problems, check connection, check everything - now printer will not do any thing - no cartridge messages, no paper jam messages, no paper too narrow message, no successful print jobs - what should I do?
  • 3 more comments
  • Mhelton Mar 24, 2008
    after days of back and forth from allign cartridge to paper too narrow, to paper jam, to align cartridge to paper too narrow, to paper jam, maybe one successful print job,and
  • infoppl Jun 18, 2008
    how do you fix this problem
  • diyfixer Aug 21, 2008
    My HP 6110 printer will not read my new ink cartridges. Message on screen replace ink cartridge.
  • gtarocket Jan 02, 2009
    Replaced color cartridge and now I get a message saying to "remove and check cartridge" what could be the problem?
  • Anonymous Jan 27, 2009
    same
Thanks to smunteanu, cleaning the optical sensor lens with a wet cuetip did the trick. Thanks so much.
Posted on Dec 03, 2008
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
812
Posted on Feb 28, 2009
HP office jet 6110 all-in-one Printer will not print off internet, comes out gibberish.
Posted on Apr 05, 2008
  • 43 Answers
Hey there.
Looking at the print cartidges in the right side you'll find a small black cap. Under the cap is hidden the calibration optical sensor. It's job is to meassure the paper and to calibrate the cartridges. Try to clean it from underneath (the lens). If it still doesn't work, you have to replace the sensor... A HP service should be you last hope.
P.S.:
The PSC 2xxx series and DJ 5xxx series have the same sensor.
Good luck
Posted on Mar 28, 2008
3 Suggested Answers
SOURCE:
  • 1605 Answers
SOURCE: HP OfficeJet 6110 All-In-One
go to hp.com, support and troubleshooting, type in your pirnter model number and download the user manual. follow the direction to disassemble the printer. you might not need to disasseble the printer, if you can see the jammed paper.
follow the direction and clean the roller and the printer head.
it should work.
Posted on Oct 10, 2008
  • 234 Answers
To start with first try a reset:
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
If not try the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00804&dlc=en&product=79477
Good Luck please let me known if nay problem.
Posted on Oct 20, 2008
I bought an HP 6110 printer and had to put a #57 ink cartridge in.Now it's saying that my paper is too narrow.I have 8.5" by 11" paper in and all my settings are for that.And it won't print if I...
Hi
after changing cartridges printer needs to alligned printheads
and this can hapen only with A4 paper
just put one page A4 in your printer until allignment is done
if i help you pls vote me
Oct 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Changed cartridges, printer doesn't align or function
Something seems to be physically wrong in the mechanism.
Try the rolling wheels and the belt on which the cartridges run.
Jul 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Printer cartridges wont align says alignment failed and then paper too narrow
I request you to perform the steps below to align the cartridge:
1. Load letter or A4 unused plain white paper into the input tray.
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges. Recycle or discard the page.
Bypass the alignment :
Press and hold the Enter button, and then press Menu
Mar 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Then check and see
Oct 08, 2008 | HP Officejet J5780 All-In-One InkJet...
it should work.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
HP 6110xi cartridge align under Vista Home Premium
it is necessary to place the allign page in the scanner and then press the enter button and the scanner will read the allign ment page as it will take 2 minutes and then it will display the message allignment complete message then it will become normal as it was .so after u get the allignment page place it in the scanner unit of the printer and then press enter.
Oct 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Cartridge alignment
It seems a problem with the carriage of the printer
printer needs to be replaced
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
830 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
