Question about LG DLE5977 Electric Dryer
Install dryer belt on a lg
Modle dle5977w hurry
  • 489 Answers
You will need to remove the front panel and the front drum support to get to the belt.
Posted on Apr 28, 2008
My lg tromm dle5977w dryer check filter light stays on and drum wont turn just makes humming noise
If the drum will not rotate then the drive belt is broken and should be replaced
May 26, 2014 | Dryers
My LG DLE5977W's drum will not turn, and makes hmmmm when I hit the start button. I can turn the drum manually; power is good as it lights up; lint is cleaned out also;
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | LG DLE5977 Stainless Steel Electric Dryer
LG DLE5977W dryer - thumping
its not the belt its the rollers you can get a kit that the belt the tensioner pulley and the rollers all come together if your replacing the rollers seeing how you already have everything apart u might as well just install the kit if your belt were broke youd have no spin you can order these from marcone or allbrands appliance they willmail the parts directly to you hope this helps
May 01, 2010 | LG DLE5977 Electric Dryer
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Dryer DLE5977W washer WM2277HW just bought used ones no operating manuals help need one for each piece where do i get them
Follow the links below with Internet Explorer ONLY, opening these files may require the free download of additional software for viewing:
WM2277W Then Click on English Manual
DLE5977W Then Click on English Manual
Aug 28, 2009 | LG DLE5977 Electric Dryer
ELECTRIC XL LOAD CAP DLE5977W
You gave me the best info to let my repair man know the problem. I cannot get to the belt and have been told it is a pretty big job and my dryer is still under warranty..so they are fixing it for me this week. Thank you for the information, it was helpful.
May 02, 2009 | LG Dryers
Felt has come off drum DLE5977W
you can't take the back of the dryer off you must take off front pop the top remove the the front take out drum and belt replace felt. Replace drum belt front and top thank you for useing fixya please rate me
Feb 10, 2009 | LG DLE5977 Electric Dryer
LG DLE5977 Electric Dryer Logo
435 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
