Question about OCE Office Equipment & Supplies
I have an OCE tds320 and for the last year we have been having a couple problems. We get a copy to late error and roll 1 or 2 is out of paper. The Tech has been in here several times and cannot seem to fix the problem. We have a service contract. But they can't seem to fix the problem. The tech keeps saying that we have a power issue but we put a volt meter and amp meter on the line and it does not show that. Or volts hold right 119volts and the amps start at 24 and drop down as the wires heat up. Does anybody have a solution. Because Frankly based on the experiance we have had with this machine I don't see why everybody say's oce's are such a good machine.
KaeZoo
  • 156 Answers
SOURCE: amp overheating and adjusting gain and frequency
Overheating in amplifiers is often caused by a speaker load of too low impedance. If your L7 is a dual 4-ohm voice coil, and if you're using the amplifier in bridged mode, that may be causing your problem. Dual 4-ohm subs, with the voice coils wired in parallel, present a 2-ohm load to the amp. Your amp is capable of running a 2 ohm load in 2-channel mode, but not bridged mode. The best fix with your equipment would be to re-wire the sub's voice coils in series, resulting in an 8-ohm load. The amplifier's power output will drop sharply, but you won't have problems with overheating in that configuration. There's a good chance that you'll still be able to get all the volume you want, even with an 8-ohm setup; otherwise you'll probably want to switch to a mono amp designed for a 2-ohm load.
Posted on Jun 23, 2007
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
freetek
  • 5568 Answers
SOURCE: high amp start up draw
I don't care what kind of stories Craftsman tells, their numbers don't add up.
One horsepower is ~ = 740 watts of energy.
2.5 hp equates to a steady-state power consumption of  ~1850W and this could be 50% higher during the first second or two after turn-on.  Your 15 Amp circuit is pushed to the limit by that power level; 15 Amps X 120 VAC = 1800W And, motors aren't a breakeven game; part of the power they draw is wasted in heat.
9 amps steady-state would be a power consumption of over 6kw which cannot be right. Either your measurements or the motor is faulty.
Posted on Dec 15, 2008
venexcsd
  • 1185 Answers
SOURCE: Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Posted on Jun 01, 2009
  • 3230 Answers
SOURCE: 0501 error with Oce' 7056
Well, error 0501 is low toner concentration problem
fill new toner and then off and on main switch many time, if the problem persists then you need to check the toner motor.
Good Luck!!
Posted on Jul 24, 2009
Oce tds error code 12502
Error 12501, Error 12502, Error 12503, Error 12504, Error 12505, Error 12506, Error 12507, Error 12508, Error, 12509, Error 12510, Error 12511, Error 12512, Error 12513, Error 12514, Error 12515
Error codes related to External Paper Input Module
Oce VarioPrint 110
Oce VarioPrint 120
Oce VarioPrint 135
Apr 28, 2014 | Office Equipment & Supplies
Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
May 03, 2013 | Office Equipment & Supplies
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Oce tds 600 Error code 15504 machine stopped in the middle of a run (like every 5 sheets) could be an overheat problem
There seems to be a feed problem. I googled the error 15504 for the Oce printer and got this page. We did this (see photo) and that seemed to sort the problem out for the meantime (until service guy gets here). I dare say it's a sensor somewhere. So jam a roll of cardboard from a used roll in behind the roller (as in the photo) and that does the trick. Hopefully this works for anyone else with the problem.
Sep 02, 2009 | OCE Office Equipment & Supplies
OCE TDS600 Error Codes
It might need a new fuse which is located where the hot wires are when the paper feeds through or it might need a circuit an Ormon G3NE-220 TL-US load 20A 240VAC 50/60hz input 24 VDC.
Jul 13, 2009 | OCE Office Equipment & Supplies
Oce7050/error code 2205
what is oce 9400 error code 0813 ?
plase help me??
msmSAS@YAHOO.COM
Dec 20, 2008 | OCE 3140 Copier
Oce 3165 Copier makes black copy over text.
that is a very expensive and big machine. as an oce representative i suggest you call it in for service.
Oct 27, 2008 | OCE 3140 Copier
OCE 7056 Toner Not Fusing To Paper
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Oct 16, 2008 | Office Equipment & Supplies
Canon Image Class D860 copier purchased 2005 - KAB-15948
dog ears are usuallycaused by paper hitting something before the fuser or at the fuser. the claws or fingers that ride on the hot rollers are getting worn or are out of place.
to determine the exact location, stop the copy at different locations by
1- make a copy
2- stop the copy by turning off or openning a door
look at the paper does it have the dog ear at that location? no stop it a little further until it does.
My guess is going to be the claws or fingers on the fuser roller.
Good luck
Dec 11, 2007 | Canon DHD860 Copier
271 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
