Question about Mitsubishi WD73727 73" HDTV
PARENTAL LOCK HOW DO YOU UNLOCK THE PARENTAL CODE ON THE TELEVISION. I BOUGHT FROM A USED TV SHOP
    Problem Solver:
  • 19 Answers
Try...in remote control next : 0000 or 1234 maybe works good look
Posted on Apr 27, 2010
I forgot code for parental lock on my RCA F32668 32" tv, please help. Thanks
RCA TV Parental Reset Code: First select parental control from the menu. You will be asked to enter your password. Press and hold the "volume +" and "channel +" buttons on your television (not the remote) for 8 seconds. You will see a message that the parental controls have been unlocked.
How To Unlock Your TV Parental Control Password
Jul 07, 2015 | RCA Televison & Video
My screen is all blue, no image and voice. a lock on the upper left corner
It sounds that your TV is locked by someway. Just unlock it. Proceed the following.
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
• Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
Sep 27, 2012 | Jensen Q2749J 27" TV
How do i disable the child lock
Sep 18, 2012 | Jensen TS2750J TV
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
Just bought a used older model rca tv parental controls locked. any master codes to bypass parental control
If you forget your password, press and hold TV on the remote and the
MENU button on the television
simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls.
Make sure you aim the remote at the TVs sensor while you press the TV button, and hold the menu button in on the front of the television.
Jan 03, 2011 | RCA 27V520T 27" TV
Bought a used tv that has a parental code on it. how do i reset or take off. Its a veiwsonic n2750W thanks
I think so unlock Parental Codes on most TV's you would go to where ever in the settings is asks to Remove Parental code. If they didnt really care hopefully the password would be generic like 0000
Dec 05, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Parental code
To reset this condition usually requires a visit to the repair shop. To clear the parental control from the AKAI brand sets, you must enter the "Service" mode of the television. WARNING: There ARE adjustments in the service menu that CAN destroy your television if improperly adjusted.
This should not matter to you as long as you are simply reseting the parental lock function.
You must have the ORIGINAL FACTORY remote. (The one that came with the television when it was new.)
With the remote press the following one at a time in order:
MUTE - 1 - 8 - 2 - POWER.
Now you should be in the service menu where you should see RESET. Select reset and enter. Turn off TV.
Your done. When you turn your set back on, the code should be cleared.
Feb 27, 2008 | Akai PT5492S 54" Rear Projection...
Quasar TV access code for parental control
same problem as discribed on a Quasar sp2722 0000 didnot unlock the parental control
thanks
Feb 09, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Parental controls
MENU button on the television simultaneously for 3 seconds. Parental
Parental Controls
Aug 26, 2007 | RCA P52939 52" Rear Projection Television
Open Questions:
See all Mitsubishi WD73727 73" HDTV Questions
Mitsubishi WD73727 73" HDTV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
