Question about Panasonic PanaFax UF-8000 Laser Fax
I keep getting a J02 error. But if I leave tray 2 empty the machine works fine.
  • nainaali4 May 11, 2010
    Here is your solution
    » Brother
    » Canon
    » HP
    » Lexmark
    » Panasonic
    » Samsung
    » Sharp
    » Other
    a
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Do you mean the 550 sheet paper tray?
    Sergeant:
  • 284 Answers
1--- check to see if any bent or folded pieces of paper are in the tray
2-- make sure the blue tab at the back of the tray is pushed up againts the paper
3--if those fail to fix.. try turning the power off and before you turn it back on.. unplug the 2nd paper tray cable from the machine and when you put it back in wiggle it up down left right and press hard .. all while the power is off and then test..
4 if that fails.. then you need a tech
Posted on Jul 14, 2010
Empty Tray
@Derekns74 How do you remove the switch? My C3000 also reads "EMPTY TRAY" constantly, even if the tray is empty and clean. It does not display the "EMPTY GROUNDS" error only "EMPTY TRAY"
If I remove the tray it display "TRAY MISSING" but whenever I insert the tray again, it reads "EMPTY TRAY"
On one occasion when our power went out, it fixed the machine, so that it stopped reading "EMPTY TRAY," but after a day or two it stopped working and displayed the same EMPTY TRAY error message again.
Aug 04, 2013 | Jura Capresso C3000 Espresso & Coffee...
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
What does error code 2 means on proline washing machine
With mine when i had the error 2 code, it was money in the filter.
Switch machine off
I had to get a baking tray and a towel, i pu tthe baking tray under the filter corner, then slowly unscrew the filter (bottom right front of machine) then let water slowy trickle into baking tray and then empty, and repeat until water stops took about 20 mins. Of course you could do it quicker if you want to flood your kitchen. :)
Then emptied the filter, then ran spin only until end. worked fine after this.
Apr 11, 2011 | Washing Machines
MY Coffee machine continues to say "Empty Tray". I
try taking the tray out and leaving it out for like 2 hours with the machine still in the on position. mine has done this before, when i reinsert the tray it will go back to select coffee on the menu. FYI - there is like a built in timer for the tray removal - I believe it will tell you what the timing is in the booklet - howver it works best to do what is stated above.
Mar 05, 2011 | Jura Capresso IMPRESSA S9 Coffee Maker
It says driptray full, but it isn't? Any ideas?
Wevhave had ours into the shop four times for the erroneous 'coffee grounds' and drip tray' emptying. They have changed the mother board, chip in the door and even looked at the head gasket and carburettor settings but can't find the source of the problem.
What we have found latelt (it's Christmas so everything is closed for a month) is if we leave it overnight without power, 3 out of 4 times it resets itself.
It's apain if it plays up during the day but mornings brings us a good cuppa more often than not.lesson-get a deLonghi next time, this Saeco brand is more trouble than they are worth.
Nov 28, 2010 | Gaggia Titanium Espresso Machine
F3 ERROR CODES
This code indicates a fault with the paper tray lift-up motor. F3-12 = tray 1, F3-22 = tray 2 etc. To clear this fault switch off at the power supply and empty the indicated tray of all apaper and jams. Operate the lift up section and then close the drawer with NO paper in drawe. Switch on again and after the machine boots up replace the paper in the drawer. This usually works fine unless there is a serious problem with the lift-up motor.
Feb 19, 2010 | Sharp AR-5320 Black and White Copier
Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Nov 15, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
913 service motor error
If this is the first time you have seen this error, do the following:
  1. Power off the printer.
  2. Remove all installed paper trays.
  3. Make sure the paper is loaded correctly in each tray. If it is not, reload the paper into that tray.
  4. Look up into the printer where the paper tray slides in and out. Check the feed (autocompensator) assembly for any damage.
  5. If everything is fine, reinstall the tray and power on the printer.
  6. Try printing a few print jobs.
  7. If the error does not return, continue using the printer as before. Keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
  8. If the error returns just as soon as you power on the printer or when you try to print again, you will need to find out which paper tray/paper source is causing the problem.
  • If the printer has only the one integrated paper tray, the problem will be with either the tray 1 pick arm/autocompensator assembly or the printer's engine/system board.
  • If the printer has more than one paper tray installed, try printing from each paper tray one at a time. The best way to do this is to have all of the paper trays empty and then proceed as follows:
    1. Put paper in tray 1 only.
    2. Print from tray 1.
    3. If tray 1 works fine, empty tray 1 and put paper in tray 2 and so on until you encounter the error message.
    4. If you receive the error when printing from one particular tray, power off the printer to clear the error.
    5. Power the printer back on.
    6. Skip the faulty paper feed slot and move on to the next one (if another one is present). If you can print from all but one of the paper trays, this is the source of the problem.
      If you have extra paper trays/drawer units installed and the error occurs from only one particular source, there are some things you can do as a temporary fix.
      • If the error is occurring from an OPTIONAL paper drawer/source, power off the printer and remove the defective drawer from the printer. You will then need to set up the printer to print from a different tray. For information on removing an optional drawer, click here.
      • If the error is occurring from the integrated paper tray (tray 1) AND you have optional paper trays installed, take all of the paper out of tray 1 but leave tray 1 installed. Set up the printer to print from one of the other paper tray sources (tray 2, tray 3, multi-purpose feeder, etc.).
    7. And if your getting the same error then you need to get it serviced...
Sep 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
Panasonic PanaFax UF-8000 Laser Fax Logo
133 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
