Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Freezer does not get cold.
Freezer no longer gets cold - any suggestions on what to check?
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerFreezer does not get cold. - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 01, 2010
Why doesn't freezer get cold enough
If the thermostat is turned up and the freezer still remains at around 10 degrees I would suggest the system coolant has leaked or the compressor is faulty. Check that the door seals are not obstructed or broken, that will stop the freezer getting colder.
Sep 01, 2014 | Bosch Freezers
Kenmore freezer gets cold and freezes but then completely dethaws itself
usually when aq defrost timer goes bad it gets stuck in defrost. I would suggest replacing this first
Mar 29, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My freezer is no longer freezing
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
Regards.
Sep 14, 2011 | Hotpoint Freezers
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Frigidaire Freezer is not getting cold LFFU1765DW9
try to vacum the coils on back, if thats the problem u will feel them get a little warm if this doesnt work try to tap the relay next to your compressor, i had this same problem
Aug 28, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Fridge & freezer no longer cold
if you only removed the ice you can see without removing the back panel then you need more defrost time yes. but the frost will come back, something in the defrost system has failed. so the answer is yes to both questions off for longer and something more serious too.
Apr 06, 2008 | Freezers
GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
141 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
