Question about HP Office Equipment & Supplies
Vertical color lines on the printout appear every time I print a page
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Try cleaning your cartridge printheads from maintenance menu
Posted on May 01, 2010
Officejet pro x476dw vertical lines after print
Run the "clean inkjets" routine followed by test pages until printout appears correct. Maybe the print cartridges are defective.
Aug 06, 2014 | HP Officejet Pro X476dw Wireless...
Hp 2600n line
after you have printed a few pages switch the machine off just as the paper leaves the fuser. then open the front cover and take a close look at the image transfer belt ( black plastic conveyor type belt)
use a torch shone accross the belt to better light the error- if you can see these Green/yellow/cyan lines on the belt then theres a good chance its coming from the toner units- ( also try print quality troubleshooting pages in the menus under diagnostics.look at the individual colour pages and look for any lines or Uneveness about the shaded colour) replace whichever toner is not printing correctly
Jan 22, 2014 | HP Color LaserJet 2600n Printer
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
All printouts have a 3/8 inch wide light vertical line -
Try an old toner cartridge if you have one. Does it do it when you use the copier function. Steven 805-520-3003
May 12, 2010 | Brother MFC 9700 All-In-One Laser Printer
THE FIRST TWO LINES OF A PRINTED DOCUMENT ARE PRINTING DOUBLE.
If your printouts contain misaligned vertical lines, you may need to align the print head. Make sure the EPSON Stylus CX3200 is turned on and not printing, and the Error light is off. Load plain, letter-size paper in the sheet feeder. Press a Menu button until you see Head Alignment, then press the Color Copy button to print an alignment page. On the test page, select the pattern with the two vertical lines most precisely printed on top of each other. You may need to use a magnifying glass or loupe. maint.6.7.1.jpg Select one pattern each for rows 1, 2, and 3. (In this example, pattern 8 is the best in each row.) Press the + or - button to select the number of the best pattern for the first row, then press the Color Copy button. Repeat this step for the second and third rows. Note: If you select a pattern other than 8 in any row, that pattern becomes pattern #8 the next time you align the print head. When you’re finished, press the Stop button.
Feb 10, 2010 | Epson Stylus CX3200 All-In-One InkJet...
The printer is printing dark vertical line on the
90% or more of the time on this printer dark lines are coming from your toner/drum cartridge. You can verify this by changing cartridges if you have a spare. If you don't then remove the cartridge and look at the colored cylinder in the cartridge and see if the same "lines" are on the cylinder that are on your prints. This will tell you for sure that the cartridge is bad.
Dec 13, 2009 | Samsung ML2250 Laser Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
Lanier 5622 Prints vertical lines
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Aug 28, 2008 | Ricoh CL4000DN Laser Printer
183 people viewed this question
Seeker5211
Seeker5211
