Question about Minolta Office Equipment & Supplies
Malfuntion detected C1300 on Di250 copier - Minolta Office Equipment & Supplies
  • Minolta Master
  • 1,294 Answers
Turn OFF the copier and turn ON again after 20 sec.This problem is in the polygon unit.If the copier working is OK,if not change the polygon unit assembly(situation under memory board).
Posted on May 08, 2010
STARTS TO PRINT,THEN STOPS AND CODE C1300 POPS UP.
print head is bad replace it if you can find one that is a legacy Minolta machine, Now Konica Minolta, try this site for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 13, 2014 | Konica Minolta Di200 Di200f Di250 Di250f...
C1300 error code Minolta Di250F
Print Head failure. The print head is what has the copier LASER inside of it. Check the connection between the print head and Master board. Replace the print head fist then board, if you can find either one. The Di250F is a legacy Minolta machine now konicaminolta.
Jan 07, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Code 1300 minolta dialta di 250 what means this ?
On a Di250 this C1300 code means that your laser scanner motor has frozen up. This unit is a small circuit board with a motor that spins a 6 sided mirror. The laser bounces off of the mirror and writes the image onto the imaging unit. You are going to have to have a service person come out and replace the motor. The cost will depend on your location but I would estimate it to be around $400.00 for parts and labor.
Good Luck and Thank You for using Fixya.
Jan 04, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
C1300
C1300 indicates a laser mirror motor failure. Given the age of the machine this is going to be expensive to repair as parts are becoming harder to find. The part that has failed is your machine is a spinning mirror that the laser bouces off of and is responsible for "writing" the image onto the drum. The motors freeze up over time and when the motor does not rotate at all or at the proper speed the C1300 code is generated. I would estimate you are looking at something in the area of $400 to $500 to repair the machine. It may be time to look at a replacement machine.
Sorry for the bad news.
WheatlandServices
Oct 19, 2010 | Minolta DiALTA Di250 All-In-One Laser...
Konica Minolta Di250 copier - Malfunction code c1300.
WheatlandServices
Oct 14, 2010 | Konica Minolta Office Equipment & Supplies
Error code c 1300 How can I fix this????
The c1300 error means that the Laser Printer needs a new Laser Unit. Unfortunately, it will have to be serviced/replaced.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Minolta DiALTA Di250 All-In-One Laser...
I have error code c1300 on konika 7415, ...help me.
C1300,
C13F0
1. Reset the malfunction.
2. If the malfunction is detected again, check the harness between, and PJ connections
on, the PH Unit and Master Board.
3. If connections are okay, change the PH Unit and Master Board.
Apr 05, 2009 | Konica Minolta Office Equipment & Supplies
C1300 error code
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and communications. For remedial actions, change the board, check for cable connections, and turn the Power Switch OFF and ON. (6) C10]] to C13]] C1300 1. Reset the malfunction and turn OFF and ON the Power Switch. 2. If the same malfunction persists, check the harnesses and PJs between PH Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
Dec 27, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Minolta Di181 C1300 Service call
my copier is minolta di 181 it shows c1300 .how can i repair this problme? thank you.
Dec 17, 2008 | Minolta DiALTA Di181 Printer
124 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
