Question about HP Photosmart C7180 All-In-One InkJet Printer
Can't get the paper out... how do we access it if it's in the way back
  • 4,041 Answers
Hello there Try this may push it out for you.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
Paper jam
Hi......................
How to Clear a Paper Jam on an HP Inkjet Printer?????
Paper jams are among the most common problem with HP inkjet printers. Follow these instructions to learn how to clear a paper jam so you can get back to work.
Instructions Things You'll Need
  • HP inkjet printer
    • 1 Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
    • 2 Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
    • 3 Look for paper through the opened back panel. Remove any paper you find jammed.
    • 4 Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
    • 5 Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
    • 6 Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
    • 7 Close the front access panel. Make sure that it latches back into place.
    • 8 Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Hope this will helpful to you...................
Good Luck.............
Sep 24, 2011 | HP DeskJet D1460 InkJet Printer
Paper jammed
    This is how to clear paper jammed in canon inkjet printer.
    1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
    2. Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
    3. Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
    4. Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
    5. Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
    6. Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
    7. Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
    8. Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam
Dec 19, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Have a paper jam I can't get to .
1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
2. Move your printer so that you'll have access the back panel. Unhinge the back access panel of the printer.
3. Look for paper through the opened back panel. Remove any paper you find jammed.
4. Close the back access panel. Make sure that it latches into place and looks the same way it did before you opened it.
5. Open the front or top access panel. This is the panel you use to access ink cartridges. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer. Go back and do that now. Look for paper that may be jammed in this area of the printer.
6. Remove any paper you find jammed here. There will be resistance from the paper feeder, so pull slowly or the paper will rip and create a more serious problem.
7. Close the front access panel. Make sure that it latches back into place.
8. Plug the printer in and attempt to print again. If you can print successfully, you have removed the paper jam.
Oct 02, 2010 | HP Officejet 6310 All-In-One InkJet...
Paper stuck
  • 1. Protect yourself from shock. Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
  • 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  • 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  • 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  • 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  • 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  • 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  • 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
  • Sep 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    Says paper jammed but this is not true
    just try this,
    1. Step 1
    2. Step 2
    3. Step 3
    4. Step 4
    5. Step 5
    6. Step 6
    7. Step 7
    8. Step 8
    Hope this helps. Please rate my response.
    Thanks.
    Have a good day.
    Mar 17, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    Keeps saying there is a jam in the paper feed, when you open the front door there is no jam, reclose it and it will print
    1. Step 1
    2. Step 2
    3. Step 3
    4. Step 4
    5. Step 5
    6. Step 6
    7. Step 7
    8. Step 8
    Thanks.
    Have a good day.
    Mar 17, 2010 | HP LaserJet 2420 Printer
    Paper jams /canon480
  • Step 2 Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
  • Step 3 Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
  • Step 4 Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
  • Step 5 Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
  • Step 6 Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
  • Step 7 Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
  • Step 8 Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
  • Jan 26, 2010 | Office Equipment & Supplies
    Paper jam - can't clear error message
    Hello Nj,
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Paper jams are was very common on HP printer model.
    Here are few instructions on how to clear the paper jam on your printer.
    How to Clear a Paper Jam on an HP Inkjet Printer 1. Disconnect the power cord from the back of the printer before you begin. With the power disconnected, you will protect yourself from being shocked. This is an important step when you are fixing any type of electronic device.
    Hope this helps.
    Aug 08, 2009 | HP Office Equipment & Supplies
    Error Paper output slot the paper is jammed.
    8. Plug the printer’s power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
    Nov 23, 2008 | Canon Office Equipment & Supplies
    When I try to print on A4 paper the Canon printer pulls on the right side of the paper only and it jams. I can still print on the small sheets (A5?) or on my 4 x 6 photo paper.
    Check to see if this will affect your guarantee and if so would probably not go ahead with it.
    Protect yourself from shock by disconnecting the power cord from the back of the Canon printer.
    Unhinge the back access panel of the printer. .
    Look through the opened back panel and look for paper or any other object that should not be there. Remove any paper or obstacle you find jammed there.
    Close the back access panel. Make sure that it latches back into place.
    Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel and look for paper or any other object that should not be there
    . Remove any paper or object you find jammed here. If you find paper pull slowly or the paper will rip and create a major problem.
    Close the front access panel. Make sure that it latches back in place.
    Put the power back on..
    Jul 14, 2008 | Televison & Video
    HP Photosmart C7180 All-In-One InkJet Printer Logo
    63 people viewed this question
    Seeker5211
    Seeker5211
