Question about Acer Monitor
Monitor going to stand bye as soon as turned on
I just bought an Acer AL2223W lcd monitor and when I hooked it to my computer I recieve the "no signal" message and the monitor goes directly to stand by. What can I do to fix this problem?
    Scholar:
  • 47 Answers
  1. Make sure your monitor is properly connected to your CPU VGA ie the screw are tight and the cable is not damaged
  2. reduce down the setting of your screen resolution to those specified for your LCD or just low settings like 600*800
  3. To do that you use your old monitor and on the desktop right click and select properties and under the settings tab select to reduce the settings to native settings or any low screen resolution
  4. Restart your PC with your LCD connected back
Posted on Mar 24, 2008
Power supply
try ebay
acerspareparts.com
superwarehouse.com
Dec 05, 2012 | Acer AL2223W 22" LCD Monitor
I just bought an acer S202HL LCD monitor and I came with no instructions Just pieces. I need to find out how to attach the stand to the monitor.
http://www.manualowl.com/p/Acer%20Computers/S202HL/Manual/82561
images?q=tbn:and9gctpxijrdqvna5o4shkopa9nys0_cz5la7mnust5rxnxgdozyaryna
Free Acer S202HL manuals!
Problems with Acer S202HL?
Ask a new Acer S202HL question
i cant get a closer look at the diagram
how many screws did it come with
Ensure that the base is locked onto the monitor stand arm
hope this helps you
Nov 28, 2011 | Acer S202HL LCD Monitor
My side bar on acer monitor screen has become white. How can I solve this problem? I was told to click on the auto configuration key but can't find it.
If you have a white bar running up the side of the monitor, then it is probably dead. Acer has 3 year warranties on their monitors so you should call them to see if you are still in warranty. If so, they will fix it free!
If more than 3 years old, try it on another pc. If it is the same on another pc, get a new monitor.
Hope this helps!
Regards,
Joe
Apr 04, 2011 | Acer AL2223W 22" LCD Monitor
Acer al2223w lcd moniter is blacking/blanking out upon boot up and also while the computer is on. any ideas on how to slove the problem?
it is the problem of the LCD panel .it is replacable .go for guarantee if not finished the period thanx plz vote
Feb 28, 2011 | Acer AL2223WD (Black, Silver) LCD Monitor
How do i remove the back cover of my al2223W monitor?
Remove all the screws and the stand, then use thin flat blade screw driver to separate them starting at the bottom edge and work your way around, be careful on the cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL2223W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Feb 10, 2011 | Acer AL2223W 22" LCD Monitor
How to remove the base
I have an AL2223W. It has 4 screws on the back that allows the stand to be removed. See if yours has that.
Jun 08, 2010 | Acer AL2016W 20" LCD Monitor
How do I take apart Acer AL1715 LCD Monitor
You do have to remove stand (the stand hinges are covered by the plastic pieces that you just pop them out) and all the screws. Start at the bottom to crack open the case. See AL1716 (almost the same as 1715):
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
http://www.badcaps.net
Apr 27, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Myscreen is too bright is it possible to change this?
You use the buttons. You press the middle button, if 3, and a menu will appear, navigate by repeated "presses" on the button, this will advance it through the items, then "Select" with the middle button, & use the buttons either side to go Up & Down, + or - in value, with the middle button as the "Select" or "End".
Feb 07, 2010 | Acer AL2223W 22" LCD Monitor
My Acer 22" AL2223W monitor display goes black after a few seconds, How can i fix it my self?
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
Sep 01, 2009 | Computers & Internet
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Apr 05, 2009 | Acer AL2223W 22" LCD Monitor
Computers & Internet Logo
197 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
