Question about Singer 8280 Mechanical Sewing Machine
LOWER THREAD IS LOOSE UNDER THE FABRIC WHEN STITCHING
    Genius:
  • 1,116 Answers
This could be one or two things; (1) the machine was threaded with the presser foot down, or (2) the timing needs to be adjusted (by a sewing machine tech).
Posted on Apr 27, 2010
Julie 2010 loose stitching on the back of the fabric
The top thread is either misthreaded or not seated in the tension disk.
Remove the top thread.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify it follows the correct thread path.
Set the top tension to the midway point and retest your machine. You may need to tweak the top tension to get both threads to meet in the middle of the fabric, but the thread nests should be gone.
Aug 03, 2017 | Sewing Machines
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
Thread balls up885-v60-v61v63-v64- v65 ce1100prw sewing machine brother sewing machine modelCE1100prw
If it is creating a thread mess (thread nest) under the fabric, either the machine is not threaded correctly or you have forgotten to lower the presser foot before beginning to stitch.
Make sure you are starting with a brand new needle!
Remove all the thread from the machine.
Check that the bobbin thread is smoothly wound onto the bobbin and that the bobbin is inserted and thread properly in the machine.
ALWAYS RAISE the presser foot and rethread the upper thread. Check that the thread path is correct.
Set the upper tension to the midway point on the dial--this is usually the factory setting but may alter over time with use. Once you get your machine stitching without a mess, you can gently alter the upper tension until the two threads meet in the middle of the fabric.
Remember to lower the presser foot before beginning to stitch.
It also helps to pull the bobbin thread up to the top of the fabric and either wrapping both thread tails around a finger on the left hand or gently holding the thread tails between the left index finger and thumb. Then SLOWLY begin stitching.
How and Why to Bring up the Bobbin Thread
You can search the internet for:
YouTube + Make + Model
and hopefully you will find some helpful videos.
Sep 26, 2016 | Sewing Machines
Why does the bottom tread come out loose and loopy
First, check the stitching to verify that it is in fact the bobbin thread that is loose & loopy. Usually, loopy thread under the fabric is the upper thread--which, if that is the case, is an indication it is either threaded incorrectly or the upper tension is too loose.
Make sure you are using a brand-new needle.
Always RAISE the presser foot and then thread the upper thread making sure that every guide and the correct path is followed.
Set the upper tension to the midway point between high & low number and re-test the stitching. Re-adjust as needed. The tension is correct when both upper and bobbin threads meet in the middle of the fabric.
Understanding Thread Tension Threads
If it is in fact the bobbin thread causing looping, it could be that the bobbin case is not threaded properly or the tension is way off.
Liz Kettle adjusting your bobbin case tension 1 wmv
Apr 11, 2016 | Sewing Machines
Harrision gc5550. Why is bottom stitching loose?
Usually, loose threads under the fabric indicate a loose upper tension. Be sure that you RAISE the presser foot BEFORE threading the upper thread. This allows the thread to seat properly in the tension guides. If the loose threads are still appearing under the fabric, try tightening the upper tension. The upper and lower threads should meet in the middle of the fabric.
Sep 18, 2015 | Sewing Machines
My bottom thread can be pulled out after stitching
Is the top thread creating loose stitches (ie, loops under the fabric)? If so, you need to tighten the upper tension. The upper and lower threads should meet in the middle of the fabric.
Sep 15, 2015 | Sewing Machines
How do I adjust tension on a Janome Harmony 9102D
Sounds like you want to do a rolled hem for a handkerchief edge, I do the following to create a rolled hem on my over locker. Take out left needle and cut and remove that thread. Open front cover and slide back lever for the stitch finger in the needle plate, this finger stops the fabric rolling under thread tension normally so you need to pull it back out of engagement. Your Janome may have a similar means to select the rolled hem or you may need to remove the stitch finger with a screwdriver, it varies between models.
Thread upper looper with wooly nylon and right needle and lower looper in matching colour thread. (You can go wooly on the bottom looper but it hardly shows so I never bother.) Disengage upper blade and move the fixed lower blade to the right to trim less, then lower upper blade back into position. Now tension, needle leave alone (5)' upper looper very loose (2-3) and lower looper tighten up to 6-7 and test stitch. You want the upper looper thread to go right underneath and the lower looper thread to disappear against the needle stitch. And the fabric to roll inside the stitching. Finesse tensions on the loopers until this is right, you may need to change blade position too, depends on weight of the fabric and how it rolls. Once this is right turn stitch length down to close up stitching, 0.8 or even 0.5 if you want full coverage. Thats it. You can use differential feed if you want a fluted rolled edge, nice on knits.
Mar 02, 2015 | Janome Harmony 9102D Mechanical Sewing...
How do i adjust the loose thread on top? Using the 3 thread stitch the top loop is loose and bulging over edge instead of smooth with rest of stitches. Setting is set to recommended setting but is still...
I always adjust my overlocker stitch in several ways. I start test serging with the blade set right out to the right so that it "fills" the stitching. I'll set all the thread dials to the middle setting, ie. 5. Then I test serge, and check the stitch formation. If the needle is looping underneath, then I'll tighten it "A LITTLE". If the looper threads are lying off the cut edge of the fabric, then I'll dial both the top and bottom looper numbers up a little to make those threads tighter.
Each fabric behaves differently depending on its "hand" so the right stitch settings do vary, ie. organza is different to heavy weight cotton or denim. So if my inital setting is then "bunching" up the fabric within the stitching, I will then lower the numbers for the top and bottom looper to release the thread some. And if the fabric is very soft and light and still bunches up, then I will move the blade over to the left some, cutting a narrower edge within the overlocking so the threads lie better.
So revist the settings, check that the cones are flowing freely, thread is into the tension devices fully, then retest the stitching. If it is the top looper only that is looping off the edge, and not the bottom as well, and they are both set to the same number, then I'd be a bit suss about the tension dial.
Feb 28, 2011 | Singer 14SH654
Rolled hem or rolled edge
You need to disengage the cutting blade by openingfirstly opening the front and left hand side covers. pull on the larger of the two silver knobs and slide the red lever towards you. I'm not sure what the tension settings are, but I'm certain you need to reduce them a fair bit to aid in the rolling effect. I only use 3 threads when doing a rolled hem.
My description isn't too detailed but I hope it helps!
Jun 11, 2008 | Janome MyLock 634D Mechanical Sewing...
Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Feb 01, 2008 | Sewing Machines
Singer 8280 Mechanical Sewing Machine Logo
143 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
