Question about Philips Lands Phones
Philips Onis 200 cordless phone
I've just inserted new batteries but suddenly don't have a dial tone for this phone. I've checked I've switched phones to check the line and it does work. Its only this phone that doesn't give a dial tone. The phone rings when there is an incoming call, but I cannot hear anything ringing out.
When I pick up the handset and press the call button it says ''Failed'' and also it is not giving me options for the base station anymore.
It seems that the base and the handset are not registered together and when I try to register it with the 4 digit code, it also says Failed.
Please help
SOURCE: GE Model 27911 DECT 6.0 Additional Cordless Handset not working
How do I get the blue light and new voice mail cleared from this phone?
Posted on Apr 03, 2008
SOURCE: Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Posted on Oct 03, 2008
SOURCE: No Dial Tone 1 Handset
I think I have the same phone. You have to put the handset with no dialtone in the main charger for about 30 seconds to reset it to the base.
Posted on Dec 25, 2008
  • 6 Answers
SOURCE: registering handset
If all else fails, read the instructions.
"4. Place the handset in the base cradle. The charge/in use indicator turns on, verifying the battery is charging. The unit will take 20 seconds to register and verify its security code. READY shows in the handset’s display."
Posted on Jan 13, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
Is Philips Onis Vox 200 compatible with Virgin phone line ?
It sounds like you have a problem with the lead connection to the phone socket.
Apr 11, 2015 | Lands Phones
GE 900 Mgz cordless phone, model 26936GE2-C
How many handsets do you have on this system? Just the one for the base unit?
May 21, 2008 | Uniden Cordless Phone
No dial tone on a cordless phone
Some units if the battery is not fully charged or any ac adaptor for another phone also connected is not plugged in you will now have no dial tone.
Dec 15, 2012 | GE Lands Phones
Hi, I have a Panasonic Cordless phone with 2 bases. I have moved one from upstairs to the phone jacket downstairs. Our third phone worked fine until I switched two of them around. Now only the plugged...
You could plug your non-cordless phone into suspicious phone jack to see if you have dial tone-if you dont have dial tone, the line maynot be connected and you should open the jack to see if there is more than 1 cable attached. If there is more than 1 cable attached and you dont have dial tone at other end of cable the cable might be cut or shorted somewhere inbetween. You can test continuity by tying 2 wires together and test with a multimeter on resistance to see if it is open circuit or maybe even short circuit. To test for short circuit, untie the cables and you should not get a reading. If you do have dial tone when you plug in non-cordless phone the distance might be to far for receiver to pick it up(ie..greater than 10 metres). I hope this has been helpful.
Aug 26, 2011 | Panasonic Lands Phones
My cordless CD275 phones is not charging. It also ahad no dialing tone and won't make or recieve calls
The phone seems to have too many issues and it seems that the handset unit is faulty. check and see if the battery had leaked into the handset. If so it might have damaged the circuit board and it might be too costly to repair.
Also check the adaptor for voltage, check the telephone line input for a failed optocoupler - no dial tone or a switching transisitor or zener diode.
Jul 21, 2011 | Philips Cell Phones
No connectivity cordless phone
Sorry you are having trouble.
Try this: Remove batteries from phones and re-insert.
Unplug base unit
Leave unplugged for about one minute.
Plug in base unit
Check for dial tone
If this does not work then get a non wireless phone and verify that you have a dial tone.
Apr 04, 2010 | Uniden Cordless Phone
The phone does not have a dial tone,but the corded phones do
hi my phone does not have a dial tone. I've tried taking out my phone from the charger but its off
Dec 28, 2008 | Uniden 5.8GHz Cordless Phone
Phillips CD235
Hi try using
0000 this is the default pin number
Dec 11, 2007 | Philips Zenia Voice Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
71 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
