Question about Simplex Kaba Ilco Unican 1000 keyless lock
I have a Ilco Unican lock I need to recode
I have a Ilco Unican LR1021B26D41 Mechanical Pushbutton Combination Lock and we have lost the code, how do I recode this lock? Is there a manual for it I can download?
4 Suggested Answers
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 963 Answers
SOURCE: We are trying to recode
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=14
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Mar 06, 2011
SOURCE: How to reset codes in Kaba ilco Unican 4000 access control
The factory-default master code for Unican 4000 is 12345678
Posted on Mar 08, 2011
How can i remove a unican lock
You will find installation manuals on this page:
http://www.kaba-ilco.com/kaba-access-control/Documentation-Support/292720/simplex-mechanical-pushbutton-locks.html
You may need to install Adobe reader if you cannot view the documents. There is a "Get Adobe Reader" link found just above the chart if you can't.
Oct 04, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
Do not no the code to my unican 5 # lock
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Aug 01, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
I can't remember the code for our 7004/7014 ilco door lock and need to reset it. Can you please instruct me as to how to do this.
I have reviewed the installation instructions and in the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
"This is a lost combination situation.
Please call our Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331."
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Good luck--and please provide feedback if this helps!
Aug 24, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need to change lock code on a gun safe
In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
or (336) 725-1331."
Jun 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
We are trying to change our code for ILCO, Unican Corp. keyless lock, serial # 743660000, model # 201049 USA (think it is model #) It appears we have lost the default code, how do we find a default code. ...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN! This is totally necessary to reset the combination!
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
Good Luck!
Jan 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I have forgotten the code for my code lock which is on my bedroom door.
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
I tried to change the code on a 1000 series lock and now I can't get any code to work
You have probably inadvertently created a lost combination situation. In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
or (336) 725-1331."
Dec 03, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Is there a repair manual available for the Simplex 1000 series locks.
aspx?id=13
Good Luck!
Nov 17, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
217 people viewed this question
Top Simplex Locks & Locksmithing Experts
Frank Mangiapane
Level 1 Expert
Michelle Balcom
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
