Question about Ricoh Aficio 450 Copier
CLOSE REAR DOOR ERROR - Rex Rotary A045
CLOSE REAR DOOR ERROR is coming continously even it is closed in Rex Rotary A045 machine. unable to scan documents also due to this error. please help
Machine: Rex Rotary A045
Aficio RW-240
  • 82 Answers
SOURCE: how do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Posted on Apr 06, 2008
  • 37 Answers
SOURCE: REX ROTARY DSM618 D SC545 ERROR CODE
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
Posted on Aug 14, 2008
idriss47
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
SOURCE: Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
Posted on Apr 30, 2009
  • 161 Answers
SOURCE: Our Gestetner A045, with RW-240WP is giving an error.
make the reader option is enabled in the server application
there should be 4 applications running
Posted on Nov 06, 2009
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
I opened my r rear door to vacum. It would not
if the jaws are closed, just pull the door handle all the way open, just like you were opening the door. You should hear a snap when the jaws open.
Nov 05, 2009 | 2007 Ford Fusion I4 SEL Sedan
DSm415pf Rex-Rotary
The photoconductor has nothing to do with the toner. Photoconductor unit (Drum) is on a 45,000 copy cycle, and comes on when the count is reached. You don't have to replace the drum until the copy quality deteriorates. The machine will continue to work
May 11, 2009 | Gestetner DSm415pf Digital Imaging Sytem
Apr 30, 2009 | Office Equipment & Supplies
In scanplot base software in A045 machine gives error when you run error is below You donot have memory access. Notice you have the instructions in user manual(RW-240 scanplot setting)? but i have checked...
This requirement and solution are in the Plotbase manual, not the copier manual. See pp. 29-30 Setting for RW-240 ScanTool.
1. Start - Control Panel - Administrative Tools
2. Local Security Policy
3. Local Admin Policies
4. User Right Assignments
5. Lock Pages in Memory - Local Security Setting
4. Add User or Group, then Advanced
5. Add or Find Now - select users (all)
6. OK
7. close Local Security Setting windows
Mar 12, 2009 | Gestetner A045 Wide Format Copier
Ricoh rex rotary sc 548
Hello wajidsn
Jan 07, 2009 | Ricoh Aficio 450 Copier
Problem with copier Rex Rotary DSc232
571 A Fusing oil overflow
• The oil overflow sensor detects oil.
• When the machine covers are
closed, the oil supply unit is not
detected.
closed, the fusing unit is not
detected.
Possible causes :
• Defective oil end sensor
• Defective oil overflow sensor
• Defective sensor cable
• Oil supply unit not installed
Jul 08, 2008 | Office Equipment & Supplies
SC542 code appears on my Rex Rotary 2822, give solution please
This means the fuser has an error. You can not reset the code even if the fault has passed without entering the service mode. If you need a service manual for this let me know and I will send you a link.
Apr 21, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Konica 3135 p17 error, wont go away
Check the rear side of the machine in the opening. You should see a small tab on the rear side of the door. This tab is supposed to go through a small slot in the cover that would then contact the door sensor/switch to tell the machine that the door is closed.
If you located the little slot, you can try rolling up a piece of paper putting it in the slot and see if you can trick the machine to think the door is closed. If you can do this then you know that the sensor/switch is working and then you would have to concentrate on the door tab that is supposed to go through the sensor. Unfortunately, if you get the machine to think the door is closed with the paper trick, you still wont be able to make a copy cause the door needs to be closed in order for the rollers to feed the paper upwards. But at least you would be able to narrow it down.
If you have any other questions, feel free to ask. I even still have some contacts for parts if needed.
Please remember to leave a feedback if my suggestion helped.
Have a good day.
Mac.
Feb 11, 2008 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
137 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
