Question about Dishwashers
Error code A01 on indesit model D73
Error code A01 on model indesit D73 less than 3 years old
  • lynne2301
    lynne2301 Jun 18, 2012
    Fixed the machine within a couple of minutes, after reading the solution . I think the drain hose got twisted when we had the machine out for cleaning, tipping it over until the water came out must have reset the float switches. Machine working perfectly. Many thanks
I looked at other people's suggestions on the web and tipped the machine over to the right side at an angle of 45deg (making sure I had old towels on the kitchen floor.) Water came out from the bottom right-hand corner. When I started up the machine it worked again.
I am writing a letter of complaint to Indesit because in under 3 years I have had to call out the engineer 3 times. Twice the door dropped on it's hinges and just a week ago, when opening the door, the board with all the electronics came away.
This is the first time I have had a malfunction as such and was amazed that a list of error messages was not in the handbook!
I shall not be buying an Indesit again. I have had a Zanussi washer/dryer for 15 years at least. It has had a new door but is still going strong.
Posted on Mar 25, 2008
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
What is Error A01 ?
this is a float switch fault
Sep 08, 2014 | Indesit Dishwashers
Riso rn 2030ui error code A01-211
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
Feb 25, 2013 | Riso Office Equipment & Supplies
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Indesit 126 washer/dryer
I have had the same problem. I thought it was the pressure switch as this is what the error code means - low or high pressure resulting in cut out. I too thought id fixed the problem but it has returned
Sep 10, 2007 | Indesit W 123 Front Load Washer
Error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Aug 11, 2007 | Indesit W 123 Front Load Washer
Error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
Dishwashers Logo
525 people viewed this question
Top Dishwashers Experts
