Question about Frigidaire ATF6000ES Front Load Washer
Washer flashing code E20?? - Frigidaire ATF6000ES Front Load Washer
    Problem Solver:
  • 7 Answers
Gooooooooooooooooooooooooooooooooooooooooooooooooood
Posted on Apr 27, 2010
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
E20 code flashing Crosley washing machine
E20 is a draining issue. You probably have objects obstructing the drain line.
May 06, 2012 | Crosley CW5000 Front Load Washer
Washer will not empty water all the way & E20 flashes on the screen. What is the problem?
2. Failed pump
Jan 09, 2011 | Frigidaire ATF6000ES Front Load Washer
E20 message want spin
2. Failed pump
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
My kenmore he washer will not drain all the water also have code E20 flashing
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Kenmore HE2 Plus Front Load Washer
E20 flashing mid cycle
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jul 01, 2009 | Zanussi ZWF1430W Front Load Washer
Atf7000ep code e20
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 code. Not draining
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zwf 1631 w
Have you took the front cover off and looked for the strainer which is located before the water pump. I have seen many of them plugged tightly, causing the water not to drain. Look inside the owners manual that came with the machine. It also should give you some things to check that would cause the code E20 to keep flashing. Hope this helps.
May 09, 2008 | Zanussi ZWF1430W Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
94 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
