Question about D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter
The device manager shows that the D-link Airplus G DWL-G510 is working properly. I have XP - SP3. But when I try to set up the network, it says that media not connected and ti=o check that the wireless switch is on.
  • prativaidya Apr 28, 2010
    Thanks, yes I am trying to connect to a wireless network. I have tried using both Windows XP utility as well as turning it off and using Dlink utility. No luck! The network access works fine on another computer.
    I can not view the network , but I used the option to add it any way since I have the WEP key, SSID etc. No luck again!
    IS there a wireless switch on the computer sometimes? One of the suggestion I got was to check if that is 'on'. Do not know how to check for the swirch and turn it on. ..Prati (still not connected).
    Any help will be greatly appreciated.
  • 550 Answers
Are you trying to connect to the wireless network ?
You are using windows XP computer. and you have D-link adapter.
In case of windows XP computer there is built in utility to connect to the wireless network. and also you have Dlink utility to connect to the wireless network.
It will be better to use the Windows utility to connect to the wireless network.
Search for the wireless network and you will see your wireless network. I believe you have the wireless router.
Posted on Apr 28, 2010
Where can i download a config utility for my D-LINK AIRPLUS DWL-G510 ADAPTER
Here is the site for the driver.
http://www.dlink.com/products/?tab=3&pid=DWL-G510&rev=DWL-G510
Dlink does not have a configuration utility for this device, so it may be that there was not one offered. Instead you can use the zero configuration utility with Windows XP.
It also states that this device has been discontinued; the driver is the 1st release driver and has not been updated.
select the DWL-G510 driver to download it, or if you have the h/w rev.2 click the FAQ and select the option for a missing "wlanapi.dll" file. There is an updated driver for this revision on the link to that FAQ resolution. For ease of use it is here:
http://www.dlink.com/products/?tab=3&pid=DWL-G510&rev=DWL-G510_revB
Good luck and I hope this helps.
Feb 24, 2011 | D-Link AirPlus G DWL-G510 802.11g/b...
I got the dwl g510 but i lost the cd and need to reinstall it but the ones i find are for xp sp3 but i got xp sp2
I sugest you install SP3 because it has fixes some security bugs in Windows XP.
SP3 is very large, you maybe able to get your computer savy friends or friendly computer shop to help you, they most likely have SP3 on a CD.
Feb 17, 2010 | D-Link FREE DLink DWL-G510 802.11g...
Will not connect to my network. PC sees my
have you manually entered the key code? did you add the device to your routers system?
Feb 04, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
I'm trying to connect to my wireless network using the d-link Airplus G DWL-G510. I can't get a connection. In the Site Survey is shows about a 50% but won't connect. My Wii uses the wireless router and my...
Ah...found it!
I think that with XP service pack 3, it caused a problem with the wireless card driver.
I just installed the latest driver, and it connected for me without a problem. Here's a link to the driver:
http://www.dlink.com/products/?pid=DWL-G510&tab=3
Hope this helps!
Jan 02, 2010 | D-Link AirPlus G DWL-G510 802.11g/b...
D-Link Airplus G DWL-G510 dose not start up
0) You must log as Administrator to enable your device
1) Check if the adapter has been installed
(My computer-->>Right click --Properties--->>Hardware--->>Device Manager---->>Network
2) You have to set the wireless connection
To set one do this:
Connecting XP
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 12, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Windows XP SP3
Hello, Lore.
Did you mean DWL-6510 or DWL-G510?
I have some comments for the last one; if it is not your PCI-card, I hope the solution is alike, at least.
My PCI-card is G510 version C and I recently posted a comment on a certain Internet Forum. See what I wrote:
First of all: D-Link simply mistreated all the costumers who bought version Cx.
The best thing to do:
1- Get the latest drivers from Australia site - www.dlink.com.au - (look for SUPPORT and not "quick find").
2- Specially for Win XP-SP3, try the USA site; you will need to follow this path because the update file is very hidden on the site: click support / FAQ / search for "G510 SP3" and see the answer for the only question that is there (so far); download the newest driver for SP3; this driver has no installer; you will have to use it as an update if you have already a driver installed (click "properties" and "update driver" on the device located at control panel / system / hardware); if you have no driver already istalled, you will have to do the opposite of DLink directions: install phisically the card before installing driver, click start / control panel / system / hardware and search for a "?" sign, click on it and provide it the downloaded driver.
Good luck!!
Jun 20, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter Logo
337 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
