Question about HP DeskJet 3325 InkJet Printer
Printout is very "dirty" i.e. toner smudge down the middle of page on a hp laserjet 2200D
  • 590 Answers
This may happen if you refill your cartridge to use again. Remove the cartridge from your printer and use a cotton bud to clan the nozzles and other leak if present.
If still your problem persists, then you may need to change the cartridge if refilled for many times.
I hope this is useful to you.
Thanks
Posted on Apr 27, 2010
My hp3600n makes a grinding sound at start and the printout always has gray verticle smudges on it
If you run the PQ troubleshooting pages you will likely find that your black cartridge is faulty. Sounds like the drum is dragging.
Aug 02, 2015 | HP LaserJet 3600n Printer
How to clean a hp laserjet 2200d
Remove left,right,back and top covers, remove fuser assembly mounted at back side,use blower to blow the deposited toner in corners of the printer, once feels its cleaned clean fuser with cotton cloth fix all parts & covers back, check for the quality, My suggestion at least minimum knoledge reuired to do this activity, breakage of plastic/trays chancess are high due to old age.
Jan 30, 2012 | HP LaserJet 2200D Printer
My printer is smudging the left hand side of the printout. How do I clean it?
Check and verify smudging not caused by toner cartridge by removing toner from printer and checking the blue roller. DO NOT TOUCH the roller as oil from fingers may cause image defects. If toner good suspect fuser causing smudging on your printouts. Note fuser not considered a customer replaceable part for this model.
Mar 11, 2010 | HP LaserJet 1320 Printer
There are smudges all along one side of the paper, changed the toner and still the same thing
The drum is probably dirty. Try removing the toner and cleaning with a clean dry cloth. Don't use a damp cloth.
Feb 05, 2010 | HP LaserJet 2200D Printer
Smudges and 'ghost image" down the page from true image,little used printer, not even a whole cartridge used
Laser Printers that printouts can be smudged usually means the Transfuser (the part that settles the toner onto paper) is not fully functioning or damaged. Simply replace it and it should be back to normal. However, these Transfusers are quite expensive. So you may be better off to get a quote for a new one if out of warranty.
May 21, 2009 | HP Officejet 5610 All-In-One InkJet...
HP LaserJet 2200 Series PCL huge dark smudge
Replace toner cartridge. If problem persist replace fuser unit. P/N # RG5-5559
Apr 28, 2009 | HP LaserJet 2200D Printer
Laser jet produces printouts that are smudged and dark
Remove the toner cartridge and use a soft cloth to wipe the photo drum clean of toner. Put it back and try again, if you still get bad prints, then you need a new toner cartridge.
Apr 01, 2009 | HP LaserJet 1200 Printer
Print out is dirty, there are smudges of inks at the page center
What colour are the smudges, if they are one colour you can try changing that colour toner cartridges. Failing this then it sounds as if you may need a new drum
Dec 09, 2008 | HP LaserJet 2550L Printer
HP Laserjet smudges across entire page
More than likely you have a bad toner cartridge.
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
Hp laserjet 2200d
If the toner smears after the page comes out of the printer you may need a new fuser. The fuser is the heating unit in the printer and can usually be seen from opening the back door. Check and see if it has a line worn down the same side as the mark on your pages.
Feb 15, 2008 | HP LaserJet 2200D Printer
HP DeskJet 3325 InkJet Printer Logo
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
