Question about Bosch Nexxt 500 Plus Dryer
Bosch nexxt 500 plus dryer does not heat up. I
Bosch nexxt 500 plus dryer does not heat up. I checked the HTC high temp cutout (black switch with red button) depressed that, but it does not have a positive feel to it when I depress it.
  • Anonymous Mar 28, 2014
    Nexxt 500series dryer
  • Bosch Master
  • 43,501 Answers
If you have a gas dryerBosch nexxt 500 plus dryer does not heat up.  I - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 28, 2010
Why does my bosch dryer not drying my clothes
will need to check the fuse thermostats also before buying new heating element, the thermal cut off may be bad, the cycling switch, the hi-lo thermostat u can test the heating element with a multimeter for continuity etc?
Dec 18, 2014 | Bosch 500 Plus Series Nexxt Clothes Dryer...
Bosch dryer will not heat
If you have a Tumble Dryer that is not heating up but the drum is turning ok, then the chances are the thermal overload cutout has tripped. Bosch dryers have a reset button but you will have to remove the heater cover panel to access it, you will find it just above the heating element (a black stat with small red button) simply press the red button and if it clicks you've fixed it.
It also may be:
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced
Dec 13, 2013 | Bosch Nexxt 800 Dryer
Bosh dryer not heating has power and the heating element is good
If I remember correctly there is a thermal cutout fuse that you can reset
Sep 06, 2012 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 plus dryer no power
could be a fuse on the main board. open the dryer and look for one either in line to the main boasts our on the main board itself
Feb 01, 2012 | Bosch Nexxt 500 Plus Dryer
Dryer not heating
Probably your high temp circuit is tripped. Replace it, you're not able to reset it. Shouldn't cost more than $25
Jan 17, 2012 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Just installed new bosch dryer it works but no heat
htc activated. Unplug unit. turn unit around and take off back panel start at top you may not have to take completely off .You will see a thing looking like a thermostat press red button put cover back on and plug unit up. this should do it.
Aug 29, 2011 | Bosch Nexxt 500 Dryer
Er@verizon.netbosch eletric dryer nexxt 500 series no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 23, 2011 | Bosch Nexxt 500 Plus Dryer
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt 500 Plus Dryer Logo
887 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
