Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman echelon 9.T furnace will not turn on. Red light blinking
Coleman echelon 9.T furnace will not turn on. The red light is blinking 3 times,stops,3 times etc
The fan will run if you turn it to 'on' position instead of 'auto' on the thermostat.
  • Coleman Master
  • 2,902 Answers
Sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Posted on Apr 27, 2010
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
I have a Coleman Echelon 9.C Series furnace that is blowing cold air. The red light flashes 5 times and the green light is flashing slowly.I had it checked several times by techsbut that can'
This code Signifies that your furnace's ROLL-OUT-SWITCH or auxiliary switch, may be open. This switch can be reset by pushing the center of red button on your furnace roll-out-switch. Make sure the heater has been cleaned out good, make sure the flue is clean, have the service company check to make sure there is not a cracked heat exchange. Call a reliable service company, not the cheapest there is no reason that they can not find the problem unless they are not qualified. If you have had a company out for the same reason and you have payed them to fix it then they have to fix the problem.
Nov 19, 2014 | Coleman Heating & Cooling
Igniter isnt lighting
IF YOU LOST POWER WHEN FURNACE WAS RUNNING IT TRIPPED ROLLOUT SWITCHES AND POSSIBLY THE HIGH LIMIT . IN CENTER OF ROLLOUT SWITCHES IS A LITTLE RED BUTTON THAT YOU RESET . YOU CAN ALSO TRY FINDING HIGH LIMIT WITH POWER SHUT OFF TO FURNACE PULL BOTH WIRES OFF HIGH LIMIT AND USE PAPER CLIP TO JUMP BETWEEN THE TWO WIRES MAKE SURE YOU DONT SHORT OUT AGAINST ANY METAL WHEN YOU TURN BACK ON IF IT WORKS YOU NEED A NEW HIGH LIMIT SWITCH.
Jan 08, 2014 | Coleman 7990-319p Evcon Gas Furnace...
BGU10016A BLINKS CODE 9
www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Nov 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Green light stays on, red light blinks along with a buzzing noise
colman uses the furnace to power the attic vent fan . Cheaper that way I guess. It just supplies your attic fan with power so it will vent thus keeping your home a little cooler in the summer.
not a big deal. you can shut the alarm with a switch ot cut power to the alarm.
Apr 19, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
How to wire a Coleman proprane furnace
I just bought a houseboat with the same furnace in it.  I will check it this weekend and provide you with the wiring directions should you still need them.
Mar 07, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
1,933 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
