Question about Kitchen Appliances - Others
I need the band that goes on the gears on the bottom of the breadmaker.
Only have 2nd gear
Check the linkage firs if it is in the right place then you will need to rebuild the trans or get a new one as the bands are gone in it. Try to change the fluids and filter first. But from the sounds of it i would say the bands are gone and it needs a new trans.
Jan 28, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
1996 dodge ram diesel no reverse
It could be a few different problems but the trans will likely need rebuilt. There is one solution that you can do with the trans in the truck. It might be that the reverse band is out of adjustment. You have to remove the bottom pan to adjust the reverse band. There is a test to see if its the reverse band. First do all the other gears work? Next drive it in Manual 1st. Does it have engine braking when you let off. If no, its the band.
Jun 27, 2010 | 1996 Dodge Ram
The gears underneath are frozen and won't turn the paddle inside the pan. Is there anyway to unfreeze the gears. It appears that the gear grease has all oozed out and the gears underneath are fused and...
The gear grease you are referring to is from the sealed bearing on the bottom of the pan. This has failed and will not allow the paddle to rotate. There is no replacement parts, and a new bread pan is needed. Sorry..Hank.
Jun 10, 2010 | Toastmaster TBR15 Bread Maker
Reverse not working at all...still goes forward with some issues.
THE FLUID LEVEL IS CHECK FROM THE BOTTOM OF THE TRANSMISSION PAN,YOU NEED A SUCTION GUN TO REFILL IT.THE INTERNAL HEX IS THE FILLER SPOT.CHECK WITH A DEALER BEFORE YOU GO FURTHER.
Feb 08, 2010 | 2002 Ford Explorer Sport Trac
How do you get the bottom off of the Breadmaker
I too wanted the answer to this question. Remove all the screws retaining the oven liner, you can then lift the oven liner out and the top plastc cover easily unclips from the bottom. To access the drive belt, remove the screws holding the chassis to the bottom cover. All that was wrong with mine was a loose retaining nut on the large driven gear - good luck!
Jan 11, 2010 | Sunbeam 5891 Bread Maker
One blade does not turn
The left blade on a BD 2300 bread maker did not turn when neading the dough. I took it apart by removing the six screws in the bottom of the case and the screws inside around the bottom outer edges of the metal insert. I then removed the screws holding the motor assembly to the base. I found that the metal plate attached to the paddle shaft driven by the gear had torn through the plastic gear, and was no longer driving the paddle. I made a new plate with the end bent down 90 degrees so that it fitted into a slot in the plastic gear. This is much stronger and the breadmaker now works fine. This is a weakness in the design and the failure could occur on either paddle. failures of the left paddle could be due to the toothed belt breaking, this drives from the right paddle gear. There is also a belt between the motor and the left paddle gear.
Dec 14, 2009 | Black & Decker B2300 Bread Machine
1998 subaru band adjustment for auto transmission.
It is on the left side hard to spot. Look below the heater hoses. Good luck, take your time and have a great day.
Jun 26, 2009 | 1998 Subaru Legacy
Need drive gear (pinion gear) for DAK FAB 100 breadmaker
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Jan 06, 2009 | Kitchen Appliances - Others
Oster 2 lb. EXPRESSBAKE: clicking sound while the kneading
Most likely you need a new band I believe you can order one for $12.95 You need to remove the bottom panel and check the band first.
Jul 26, 2008 | Oster 5838 ExpressBake Bread Maker
My breadmaker is not turning properly.
Try either turning the paddle slightly until it aligns with the "gear" under the bottom of the pan.
I've also pressed the start button, and when the mixing process began, managed to push the pan down until it's engaged properly.
Apr 16, 2008 | Sunbeam 5833 ExpressBake Bread Maker
Kitchen Appliances - Others Logo
13 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
