We suddenly have no heat or hot water in our house. We have a full oil tank. oil fuels our hot water & heats our house. our heating type is water baseboard heating. (i think thats what its called) what could be causing this?
  • 661 Answers
The burner for the hot water is out for some reason. There could be many reasons for the burner being out from it being clogged to a bad sensor. You really need to have a technician come out and troubleshoot it.
Posted on Apr 27, 2010
Ran out of oil, when refilled managed to get heating working but oven not
How to bleed and restart your oil heating. - Instructables
www.instructables.com/.../How-to-bleed-and-restart-your-oil...
InstructablesGo to the oil tank and make sure there's oil in it, or you'll be wasting your time. ... you to get lucky but it has happened to me and it seems to help get the fuel moving a ... I am thinking the boiler is not working so do not want to spend money buying lots of ... Bleeding brilliant - now the wife doesn't have to know we ran out of oil!Missing: oven
how to mend it .com - Clearing airlock from riello oil burner?
www.howtomendit.com > Heating, Oil Filled Radiators
The temp knob on my bosch oven has stopped working. ? Search: Go ... I've now replensihed the oil but the system keeps cutting out after a few moments trying to ignite the oil. ... With guests arriving to rent my house yesterday, I ran out if fuel,refilled and ... Have now managed to restore heating and hot water to my house.
My Craftsman lawn mower wont start after it ran out of gas ...
www.shopyourway.com > Manage My Life > Questions
Dec 21, 2015 | Ovens
Oil furnace only produces cool water intermittedly and only when heat is actively on
For clarity, a Furnace produces HOT AIR for heat while a boiler produces HOT WATER for heat. Just remember...boil = water. You said your "furnace" does not produce hot water for a shower and because furnaces do not product hot water unless they have some model that do???? Usually people with a furnace have a seperate hot water heater. People with boilers though can produce hot water for use as both their sinks/showers hot water and their heat (by heating water that goes through baseboards) in their house. I don't believe any furnaces produce hot water most of the time a furnace just produces hot air for heating. So figure out what you first have.
Having said that, I'll assume you have a boiler like I do and my Weil McClean(sp?) stopped working a while back and wasn't turning on to "boil" any water. I took apart the burner and there is a light sensing photo resistor as part of the controls. If this phto resistor goes bad, the boiler will not start. The resister is cheap, I think it was $8 but you have to know what you're doing to change it. So you may be better to call someone who can work on such equipment.
Boiler's themselves are not overly complex. Home heating oil is the same diesel fuel that you can buy in a gas station only the government has "oil" companies put a RED die in home heating fuel which is usually cheaper then Diesel fuel because diesel fuel is taxed to death. The reason they do that is so that if you try putting RED tinted home heating fuel in your truck and you get pulled over (because you're a trucker with and 18 wheeler and they typically do inspections of these trucks) you will be a huge fine if they see you're running home heating fuel and NOT paying your taxed by purchasing Diesel fuel. A little bit of background so you know the fuel you are dealing with here. So it's dieslel fuel without the tax you run in your boiler. Gasoline on the other hand is VERY explosive as you know, but diesel fuel (if you're ever tried to light it) takes some coaxing to get lit. When it's cold out, diesel fuel is very hard to light and that's why trucks use glow plugs. You don't need those in your home though.
But because diesel fuel/home heating oil is hard to light, it's sprayed as a msit into your boiler, so that it can light more easily.
But because it is a fuel, you should know what you're doing when messing with it. FInd out what you have, and then have someone work on the issue if you haven't already. I'm guessing you have had it fixed by now?
Mar 21, 2014 | Water Heaters
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
http://waterheatertimer.org/Crossover.html
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
Hot water not going, wanting to know how to turn it back on?
You have a real good description of your thermostat--
I wonder why you suspect the thermostat to be causing your 'No Hot Water' problem?
First of all, I have to be sure I understand your real problem--
When you say you want to 'turn the Hot Water back on', (It is 'Not going')
Do you mean you want a boiler (maybe in the basement?) -- or maybe a zone valve in a Hot Water, Baseboard heating system-- to be heating your house/ room/ apartment?
I would suppose, if you have the thermostat set higher than the room temperature, that it should be giving a 'call' to the boiler (or Baseboard Hot Water Heater..) to ignite a fire, and heat the waer, and then heat your room, or house.
So-- Could the problem be in the Device heating the Hot Water?
Please tell us more about your heating system-- what type of fuel, -- What happens when you lower the Thermostat, and then raise it-- What used to happen, and what does NOT now happen, etc.
Tell us more clues-- maybe we can help remotely like this-
Mack B
Jan 26, 2011 | Emerson Fans 300 Heating & Cooling...
I live in Wisconsin (so it gets cold) and I just built a 1,000 sqft detached garage with 9' walls and I looking for the most efficient way to heat it. I will generally only be using it on weekends, but,...
Hi Rob - There are a bunch of variables that come into play. If you're going to use liquid fuels such as K1 kerosene or "home heating oil" (red dyed diesel fuel without the "road use tax"), you have to consider the tank location. Since home heating oil is really dyed diesel fuel, is reacts to cold just like diesel fuel does. It begins to gel - paraffin separates and the fuel gets cloudy around the 20 degree F mark and can clog the supply lines and filter. It gets worse as it gets colder. You can get around this somewhat by installing larger diameter and insulated fuel supply lines and moving the filter bowl assembly inside where it won't be subjected to that much cold. Your dealer may put additives in the fuel to prevent separation or you can add it yourself. K1 can be added to home heating oil tank to reduce clouding and straight K1 can be burned by an oil burner (you can not burn home heating oil in a K1 heater though). K1 on the other hand, flows just fine at these temps and lower. You'll need to supply storage tanks for these fuels.
The amount of heat or BTU's per gallon of these two fuels is significant. Home heating oil checks in with 50% more heat with around 140,000 BTUs per gallon while K1 has just over 90,000 BTUs per gallon. Cost is another factor. Typically, K1 sells for more than home heating oil, but has the benefits above. Prices for home heating oil and K1 are volatile and change daily and from dealer to dealer. Many dealers will lock prices and / or offer purchasing plans.
Next is natural gas (or just plain "gas") and propane (or LP). Gas is usually delivered via underground supply pipes and propane is delivered by truck to your on-site tank in areas that don't have the underground gas pipe infrastructure in place. The LP dealer will usually supply and install an above ground tank. You'll likely have just LP or both LP and gas available in your area. Heating appliances must be set up to burn one fuel or the other - not both. It is often a relatively inexpensive operation to convert from one fuel to the other, meaning separate appliances for either are not required. Gas prices are usually fixed for different times of the year, while LP prices may change daily and based on the volume used. Lower usage customers often pay more than their next door neighbors that use more from propane the same company. Like home heating oil and K1 dealers, many companies offer price locks and purchasing plans.
Gas and LP heating appliances burn "clean" meaning that there is little smoke, soot or tuning needed. Oil and K1 however, require regular tuning and cleaning to achieve maximum efficiency. Oil and K1 will burn but not rapidly combust - as gasoline would. LP and gas however, will explode if allowed to collect in an enclosed area and ignited by spark from a ringing telephone, etc. Prices of the heating appliance itself come into play as well.
You can heat the space by your choice of fuel and method of heat delivery. Forced hot air is probably going to be your best choice, but you could choose a forced hot water system if you add antifreeze to it. You'll also need a source of water to make up any lost due to pressure relief valve discharges, etc. If you chose the forced hot air system, you could probably get away without the expense of duct work - where a forced hot water design will require baseboard radiant heaters or a fan forced hot water coil.
That should be enough to get you thinking.. good luck!
Lastly, electric heat. Electric heat is 100% efficient, but is probably the most costly to operate. It's listed because it is available - not because I recommend it.
The best thing you can do is insulate. Insulation pays you back quicker with each rise in fuel costs. Put money into proper insulation as you can. Low E glass in your windows, weather strip doors, etc.
Nov 12, 2010 | Heating & Cooling
Currently have leaking expansion tank and have shut off main water to minimize water in basement (also have bucket under leak). Have forced hot water for heating house if have main water off can we keep...
HI sorry its shot, they go every now &then.You can run it like you say temporary BUT the boiler needs low pressure to force heat @10 or 12 p.s.i. This pressure will leak out of the hole and you eventaully loose heat & get noise.If you got a pinhole leak in tank.With the main off.Slow it down with duct tape or a rag if you can and leave water on.
Mar 30, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
I have a riello oil burner, starts to fire up for a few seconds and fails , fuel is ok any ideas please
i have a riello oil burner 40 F5, starts to fire up for a few seconds and fails , but then it will start for a few minutes...then shuts off... house is not being heated sufficient. There's hot water but after one shower the water starts getting cold....fuel is ok any ideas please
Nov 28, 2009 | SySTOR Systems (400S52) Burner
Asko dishwasher d3530. The water in the dishwasher is not hot.
Generally speaking, dishwashers don't heat cold water on their own. Be sure the dishwasher is connected to a hot water supply and that hot water is available to the dishwasher at the START of the cycle.
Often it takes hot water several seconds for house plumbing to deliver hot water to an outlet. If the dishwasher is connected to the kitchen hot water supply, run the water in the sink until the water runs hot before you start the dishwasher.
Dishwashers often have heaters to heat the water even hotter than most home water heaters, but they are not intended to heat cool or cold water. You MUST furnish hot water to the dishwasher from the time the cycle is started.
I've seen houses that take so long for hot water to reach a faucet, the dishwasher is already full (of cold water) before the first drop of hot water reaches it.
Good luck. Hope this helps.
Sep 11, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Central heating and hot water have suddenly stopped working
not an engineer but maybe a heating compant,, it sounds like you have a relay that has gone bad, you have what we call a winter summer system your domestic water comes from a tank inside the boiler, you might want to think about splitting the system to save you some money in the long run, seperate the water heater from the boiler so you only heat up in the winter, right now you are heating the system that heats your house to get 30 or 40 gals of domestic hot water, it would cost you less by seperating them
May 17, 2009 | Water Heaters
30amp breaker labeled heat strip trips and no hot water
That 300 amp breaker must be controlling both your hot water tank and some heat strip somewhere in your house which is designed to either prevent a pipe from freezing or melt ice on the eves of your roof.
please mark this answer as a fixya
Mar 05, 2009 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
