posted by mastoo on Mar 24, 2008
i have installed windows vista service pack 1 on a preinstalled vista image. Now im facing problem to create a single dvd as recovery dvd for vista with spk1. I want to know how to create bootable dvd with install.wim file.
Best Solution
posted on Mar 24, 2008
How To Make Vista Bootable DVD with WIM Downloaded Files
If
you have purchased Windows Vista online and taken the delivery of the
latest operating system via web download from Windows Marketplace, you
would ends up with a few downloads with .wim and .exe file extensions.
Rather than paying additional shipping and handling charges, you can
burn or create a bootable ISO DVD image from downloaded Vista files
with the following trick, where the .iso image can subsequently write
to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD
that available in retail channel, and can be used to clean install.
How to make a bootable Windows Vista ISO DVD media
1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
3. Exit from the Install Windows screen.
4. Download CDimage 2.52
5. Extract CDimage from CDimage.zip to the C:\ root directory.
6. Open a command prompt shell, and run the following command:
cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK)
1. Complete step 1 - 3 as above.
2. In the command prompt window, run the following command:
oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
3. Burn the ISO image file by using last step above.
Rating Locked! (?) mastoo has rated this solution as Helpful
This Problem Also Relates To:
HP Red Hat Enterprise Linux 3 ES Standard for x86 for Linux
Apple (691-2818-A) for Mac
Apple Mac OS 9.1 (M8081LL/A) for Mac
Cisco IOS Advanced IP Services 12.3(11)T (S384UASK9A12311T) for PC
Cisco IOS Enterprise Basic for PC
Cisco IOS Enterprise Services for PC
Cisco IOS Enterprise with IPv6 12.2(17b)SXB (S222A12217SXB)
Can you Help with these Operating Systems problems?
Microsoft Windows Xp Home Edition Sp2 English...
no sound no speaker icon
no sound and all the options in... Answer This...
Microsoft Windows XP Professional for PC
WINDOWS XP SOUND DRIVER...
dear sir, i want to your help,... Answer This...
Repair Service
Find Operating System Repairman Near You:
