Question about Gaggia Titanium Espresso Machine
On screen showing rinsing cycle close knob what should i do?
My GE Front Load Washer (model WPXH214FWW) remains in the 'drain' cycle between the main wash and rinse cycles. It will only move to the next cycle if we manually advance the knob (slight turn)after which...
Before replacing the timer, check the cold water inlet. Rinses usually use cold water only. The screen inside the valve, right where the hose screws onto the machine, may be blocked. If not blocked, check the inlet valve solonoid coil to see if it is open and in need of replacement.
Oct 15, 2008 | Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Machine stopping prior to rinse cycle, not draining.
Hi Jackie, more than likely you have a timer control failure. It's an easy fix if you have money and can afford a repair man to fix the problem. It's a lot better plan if you have friends with a few skills. Just need to enter model number of your washer on ebay and ask for a replacement timer. It is behind the cycle control knob on your washer. Invite a couple friends over for a cookout and repair your washer. Don't have any friends? If close enough will be glad to help. Simple fix, have fun, good experience. Stan
Apr 02, 2017 | Kenmore Whirlpool Duet Sport Washer Door...
Cold water knob is not working
Check the screen on the cold valve. If power is getting to the valve and the screens are clean then the coil is bad. Check continuity if you have a meter.
eric
Jul 01, 2009 | Washing Machines
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Decalcify
when the machine gives the signal press the bottom right hand button for 5 seconds.
it will tell you to open the knob.
before you open the knob fill the water tank with the descaling solution
place a large water receptacle under the steam wand.
now turn your knob
the machine will start to descale this can take a while
when the descale cycle is finished close the knob.
rinse the water tank out with fresh water and fill it will clean drinking water.
Press the same button on the bottom right to confirm that yo are doing the rinse cycle.
open with knob and the machine will start the rinse cycle.
when the rinse cycle is complete close the knob and load the circuit.
when descaling is over fit a new cartridge filter in your water tank and off you go with your descaled cleaned coffee machine.
May 21, 2007 | Saeco Incanto Classic Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
51 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
