Question about Guess Steel Multifunction #G95291G Watch for Men
I cant open to replace battery - Guess Steel Multifunction #G95291G Watch for Men
What kind of battery do i need???!!!
Open it up, take the battery out, and that will tell you.
May 26, 2015 | Watches
I have a TCM radio controlled mans watch , I have replaced the battery now I cant put the watch at the right time can you help please
Sep 13, 2010 | Watches
How do i remove the back on my sekonda mens watch
mcdevito75 here, Generally thr back is simply pryed off useing a sharp knife (steak) or with a case opener, or at times the back is screwed on, little square holes around the back of the watch require a special tool, or there may be 4 screws holding down the back to the case, even if you get the back off you may need Jewelers screwdrivers to remove / replace the battery. BEST BET, look for a small watch repair shop in your area.
Jul 12, 2010 | Watches
Cant figure out how to get back of watch open to get to battery to replace it
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 19, 2010 | Watches
My watch needs a new battery.
There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
Nov 10, 2008 | Swiss Army Wenger Sportedge Bracelet Watch
Open back
Hi cinannh,i have sample video guide of how to open ,tell me whatever the result ,so i can assist...
How to replace a watch battery - Watch
hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Pulsar PPG672 Ladies
I just replace the battey on a g shock dw 9050 and i cant set the time i shows the time but at the top it flashes TYO
Did you ground the battery? If not you need to open up the watch and find the ground and take a tweezer and touch the top of the battery and the ground.You should be able to move on from there, if not are your buttons making contact with the movement?
Jun 29, 2008 | Watches
Watch stops
i have no solution but i cant even get mine open, how do i open this? rich@potterandco.com
Nov 01, 2007 | Watches
Guess Steel Multifunction #G95291G Watch for Men Logo
75 people viewed this question
Top Guess Watches Experts
Jimmy Accardi
Dennis Fitzsimmons
Level 1 Expert
Are you a Guess Watch Expert? Answer questions, earn points and help others
