Question about Dishwashers
Diplomat dishwasher error code F4? not draining water away?
  • 3422 Answers
SOURCE: Diplomat intergrated dishwasher error code FA
The wash cycle finishes too early and
the p / 6 indicator light flashes
(fault code F A appears in the
display)
– the drain hose is kinked
– the drain pump is blocked
* Turn the program selector to the f
*STOP" position (the fault code goes
out).
* Correct the fault.
* Pump away the water and start the
program again (see additional
program "DRAIN" and "Switching
on").
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 03, 2008
rylee_smith
  • 8619 Answers
SOURCE: Whitlpool dishwasher problem
Hi
Error code F4 means its a drainage failure. If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please revert for further clarifications and Do rate the solution as FixYa if found useful.
Thanks
Rylee
Posted on Mar 15, 2009
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 82 Answers
SOURCE: error code f4 on my
Blocked waste outlet or maybe just a worn pump.
I fixed a new one today showing F4
I found a piece of broken glass stopping the waste pump.
Hope this helps
john
Posted on Aug 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
Diplomat dishwasher adp8332, keeps beeping before end of cycle F4, cant find manual ? any suggestions
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Dec 30, 2011 | Dishwashers
Hi! I have Whirlpool ADP6948 dishwasher. It's
Hi.
F4 points at at a drain problem, often the problem is caused by a dirty or defective pressure switch. Before replacing the pressure switch it is necessary to test the drain system.
First try turning power off from circuit breaker for few minutes and see if that is enough to clear the error code.
Turn power off from circuit breaker (or disconnect power cord) and clean the drain well inside the tub. Remove any water present in the tum. Check also the drain hose at the back of the appliance and make sure it is not kinked or blocked.
If that does not work remove the kick panel at the base of the dishwasher, locate the pressure switch and clean the hose connected to the pressure switch. The pressure switch is the device that detects water level, determining when to start and stop the drain pump. The pressure switch is a small plastic switch connected to a long rubber hose. If the hose gets blocked with detergent or if the switch is defective you get f4.
Resuming:
Try resetting the appliance to clear the error code.
If that does not work clean and check the drain system.
If still no luck check the pressure switch.
Disconnect power before doing any maintenance.
Regards.
Ginko
Aug 31, 2011 | Whirlpool Dishwashers
2LYMPAIA - F4
Hello
If you have F4 and the sump is full of water, there's a good chance the drain pump is being jammed by a broken bit of glass or pottery. However, if the appliance is empty of water and F4 error code is flashing, where do you go from there?
The electronic control (module pcb) does a self check of the components, during a drain cycle the programme allows a time parameter for the appliance to empty away the water. How does the pcb know the water has gone? Simply by testing a pressure switch for continuity.
The pressure switch is an on or off switch, when the appliance is empty the internal contacts are "made" (on) when the appliance is full of water the switch is "broken" (off).
The sensing grid of the pressure switch is exposed to the dishwasher wash water and can over a period of time get clogged with crud ( a mixture of food waste and detergent and limescale), eventually this crud stops the switch from being in the correct attitude during the self tests. The electronics notes the on or off and determines that the appiiance has not drained and gives error code F4.
If you have F4 error code it could be the pressure switch needs cleaning or replacing.
On the self test about 4 mins is allowed for the appliance to empty the water away.
Aug 03, 2011 | Whirlpool Dishwashers
Hi do you cover advice on Diplomat diswashers? I understand they are Whirlpool products rebranded. I have an F4 code fault that comes up mid cycle on an 8332 model
Greetings,
this is a drain fault code..I would suggest to clear out the sump and check that no one has replaced a disposal and forgot to knock out the drain plug...check for blocked drain hose...
Nov 16, 2010 | Dishwashers
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Whirlpool dishwasher adp550
f4 is a drain error, machine is still sesing water has not pumped out after 4 minutes of draining
1st check and see if water is still in bottom of machine if so check for blockeges under sink where drain hose cnnects to drain pipe.
if water has drained out you may have an water sensor fault or worst case an electronic control board fault
to reset machine hold the start button in for at least 3 seconds and it should do a drain and stop
Feb 19, 2008 | Dishwashers
Dishwashers Logo
392 people viewed this question
Top Dishwashers Experts
