if you look at the console you should see a button with a lock next to it and it should tell you told hold the button in for three second to lock it and hold it for three seconds to take it out
This might work try unplugging it for about 45 -60 seconds and see if it clears the problem. The red light is some type of warning and I would be safe in saying it is a safety device gone bad. Sorry I couldn't be of more help.
Col. Dana Gillespie
The control is locked and you can unlock it by pressing and holding the End of Cycle button for 3 seconds or until the
Control Locked indicator turns off. Unplug the machine for
at least 30 minutes to forcibly reset the control and eliminate the possibility of an electronic glitch if the End of Cycle
button does not unlock it. Replace the control if unplugging and the End
of Cycle button fails to unlock it.
Press any of the buttons on the control panel to see if the buttons are
operational or check to see if the "Control Locked" indicator light is
lit. If the control panel is operational, you may mistakenly lock the
door.
Press and hold the "End of Cycle Signal" button for
approximately three seconds until the "Control Locked" indicator light
shuts off.
Hello,To turn off the control light... select and hold the End of Cycle
signal for 3 seconds. It will turn off and the machine will work
properly! Thanks
