Question about Initial HDTV-320 32 in. LCD TV
Won't switch input settings
My Initial brand LCD HDTV will not switch input settings. It doesn't appear that it is recognizing the signal from my remote controller, and it also does not respond to any of the buttons on the actual TV itself. Basically it is stuck in one mode. I've only had this TV for a year and a half, so I'd like to fix it if possible!
I don't know if this is enough information or not. If I need to provide more, please let me know!
marie
  • smgudz Apr 27, 2010
    The TV originally worked for a year, and then stopped when I was away on vacation, so this appears to be an acquired problem, not something that was wrong with it initially.
  • 666 Answers
This is a manufacturer defect I would suggest contacting them and hopefully getting a replacement for it or at bare minimum they should give you a means to reset the tv to its manufacturer default hopefully enabling the features that came with it
hope this helps
Posted on Apr 27, 2010
Proscan tv will not receive or recognize cable or video signals when all plugs are in as prescribed. Have removed power supply waited to attempt to clear it. Restarted and still get no signal message. We...
Here are a few ideas:
  • The No Signal, No Source or No Input message will appear on your television screen when the television is not receiving a signal from your Digital Box. This is often a result of either the Digital Box being powered off, not being properly connected to the TV, or if the TV is set to the wrong input.
  • Press the "TV/VCR" button on your remote control if you are experiencing no picture. This button will allow you to toggle between TV and VCR screens and may solve your display problem.
  • Make sure your cable box is turned on.
Jan 21, 2018 | Shopnbc Proscan 32" 720p 60Hz LCD HDTV w/...
"NO SIGNAL "is displayed on a blue screen
You have selected an input on the display that is not getting any signal that the display can recognize. Press the source button either on the set or on the remote until you get a signal.
Aug 09, 2012 | Element Electronics FLX-1910 19 in. LCD...
I am trying to use an HDTV as a computer monitor. The TV model is "Initial HDTV 262. The sales literature says that it can double as a computer monitor. I do not have a remote control for the TV. Does...
Most TV s have button controls on the side, top, botom or back. You should be able to choose the menu option the use the up and down arrows on the volume or channel to control the menu options. Once you set the input source you should be good to go.
Mar 11, 2017 | Initial DTV-262 26 in. HD-Ready LCD TV/DVD...
No input signal hdmi
Make sure the HDMI connection is secure. Madke sure it is on the correct input. Turn on the peripheral first, i.e. dvd, cable box, etc. then turn on the tv. If you still have problems, test whether or not the HDMI cable is bad by trying with another device. If okay, make sure the device or peripheral works with a different type cable. Try to change the inputs from HDMI input 1 to say HDMI input 2, etc. If you can't get HDMI to work just switch it to component. HDMI video is not Superior to component it just affords one to have true 5.1 surround sound broadcast.
Mar 23, 2011 | Initial HDTV-322 32 in. LCD Television
Remote doesn"t work. Only have
check that all of your cables are plugged in correctly and that the input is set to to correct cables on the remote there is a button that should say input press that a menu will appear and then you can scroll through your input options keep trying until one works
there is also usually a button on the tv that does the same thing
Mar 06, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
How do i get the tv off of anteena signal to cable signal
I could be more specific if you described what brand/model you have but you need to change the input. Depending on where you have the cable input from the box, you'll need to set the tv to that input (video 1, hdmi1, component, etc).
Sep 13, 2009 | Vizio VW32L 32 in. LCD HDTV
I cancelled my dish hooked up a anttena but no signal
Go to main menu and select settings, initial setup, TV signal input, select Antenna, go to channel scan, select digital channel scan if there is a choice, or else channel scan. Wait for the scan to complete, 3 minutes or so. Exit menu, go to input and select ANT.
Wah Lah!
Jul 03, 2009 | LG 42LC2D 42 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
HDMI input problems
HDMI is suppose to carry sound. With the rest of the symptoms you describe, the first thing I would try is to replace that cable with a good quality one.
Mar 26, 2017 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
Initial HDTV-320 32 in. LCD TV Logo
177 people viewed this question
Top Initial Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
