Question about Kitchen Ranges
I have a maytag electric range, model# mer5730aaw the front right burner gets cooks like its on high when its set to low. replaced the switch now it cycles on and off only on the high setting, you never see the element come on. i looked at the schematic to see how to wire the switch so i know that is right. is there a sensor thats bad or is it possible my switch is defective
  • J-run Apr 28, 2010
    thanks
    President:
  • 1,469 Answers
Hello
If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repair person.
If your range has a pilot light, be sure the pilot light is lit.
if a burner doesn't work at all:
1) Be sure the circuit breaker serving the appliance is in the "On" position and that its fuse has not blown. Check both the main electrical
panel and any secondary sub panels that supply power to the furnace or appliance. If necessary, reset the circuit breaker or replace the fuse. If the circuit blows again, there is probably a short in the electrical system.
2) Be sure the appliance's switch is turned on and that the appliance is plugged in.
3) Be sure the appliance's power switch is turned on. This may be on the appliance or, in the case of a gas furnace, next to or inside the furnace cabinet. If it isn't on, turn it on and wait a few minutes.
4) Be sure the thermostat or heat dial is set properly.
5) If the appliance has a pilot light, be sure it's working.
When an electric element doesn't work, either it isn't receiving electric power or it's likely that the element or receptacle it plugs into is faulty.
Check the other elements. If none work, the circuit breaker has probably tripped. Reset it at the electric panel. If the problem reoccurs,
If just one burner isn't working, try to pinpoint the source of the problem, which will likely be a bad element/burner or a problem with its connection receptacle. In some cases it's the switch or the wiring. To replace a bad switch, repair the wiring, or replace the receptacle, use the manual.
A burner that plugs into a receptacle is easy to test. After turning off the range's power at the main electrical panel, just unplug the non-heating burner, plug it into another working receptacle, restore the power to the range, and test it. If the burner works, you know its original receptacle is probably faulty. If it doesn't work in the good receptacle, the burner is bad and should be replaced. Buy a replacement, and simply plug it into the receptacle.
When you remove the burner, look for burned wires or a charred receptacle. Check the receptacle or terminal block to see if it's cracked, loose, or looks burned. If you notice any of the above signs, replace the faulty component, too. If the male burner prongs are corroded, always change the female receptacle it was plugged into.
God luck.
GA_googleFillSlot("HT_Appliances_Ranges_Ovens_Articles_Referral_BL_181x151");
Posted on Apr 27, 2010
Right large burner cooks on high no matter what setting.
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Jun 08, 2010 | Hotpoint RB787BHBB Electric Kitchen Range
Not enough gas to range?
you either have a gas pressure problem from your meter outside or a bad pressure regulator on the range. if you use a magnehelic guage (get from a plumming supply house) you should be getting about 11inches of water coloum, or you can call your gas company to check it out... Let me know how it goes.
Jan 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Burner temp.
If set to high, burners should remain on. If set to medium high let's say, they would be on for maybe 70 percent of the time, off for 30 percent of the time. If set to warm, they might be on only 10 percent of the time, off 90 percent. There is a high temp limiter which could turn a burner off. If you have a burner on high and are cooking on that burner and it goes off, the high temp limiter may be faulty. It is an integral part of the burner, and would require replacement of the offending burner. Burners are individually replaceable after lifting up the glass cook top.
Oct 19, 2008 | GE JBP66 Electric Kitchen Range
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Problem with Jenn Air Gas Range???
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
Jan 02, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
