Question about Canon imageRUNNER 4570 Copier
How do i clear the fax address book? - Canon imageRUNNER 4570 Copier
  • 62 Answers
If not used as network printer you can use Initialize All Data to remove all settings.Initialize=ERASE>>> WARNING>>> this will remove all settings for header,number,user boxes,network settings. Unless you print all of these other settings for fax - network(Additional Funtions Report) and remember how to re-input DO NOT USE THIS.
You can have a fax tied to a one-touch button and that will prevent you from deleting from the fax screen.
1st>Send tab>reg.tab>Register One-Touch Button>Highlight Name>Erase tab will activate touch Erase>Yes to confirm
2nd>Send tab>Address Book>Register>RegisterAddress>Highlight Name>Erase>Yes to confirm
Posted on Jul 09, 2010
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
How do i change a speed dial number on my brother mfc-7340?
Changes to the contents stored in the address book do not become effective in the stored speed dial numbers in Windows®. Description:If you have made a change to the contents stored in the address book, the speed-dial is NOT automatically updated.
If you change the address book entry, please follow the steps below to store the speed dial number again.
  1. Click on the setup button to open the Brother PC-FAX Setup dialog box.
    Notes:
    You can also access the Brother PC-FAX Setup dialog box by clicking start => Programs => Brother => MFC-XXXX or MFC-XXXX LAN (where XXXX is your model name) => PC-FAX Sending => PC-FAX Setup.
  2. Click the Speed Dial tab.
  3. Select the Speed Dial No. which includes the member or group you made a change in the address book, and then click Clear.
  4. Click the Speed Dial No. you want to program.
  5. Click the member or group you want to store on the Speed Dial again and click Add.
  6. The Speed Dial is now registered with the new entry. Click OK.
If you put the patch below, the message that prompts you to confirm the destination number or address will appear when you send a fax using the speed dial. Also the message that indicates changes in the address book do not become effective in the stored speed dial numbers will appear when storing a speed dial.
  1. Make a temporary folder on your HDD [hard disk drive] as the location to save the downloaded self-extracting file, e.g. C:\brodnt
  2. Please click here to download the patch. (7.07MB)
  3. The Brother End-User License Agreement will appear. If you agree to the terms, click I ACCEPT.
  4. Download the file to the temporary folder created in Step 1.
  5. Once downloading is complete, open the folder and double click PCFAXUPD.EXE.
  6. The installation will start. Please follow the on-screen installation directions.
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Brother MFC 7420 All-In-One Laser Printer
Unable to change names/add addresses in the address book faxing
Try Googling (Kyocera)(KM-3035)(manual) without parens for instructions.
Nov 03, 2017 | Kyocera Mita KM-3035 All-In-One Laser...
How do I clear all e-mail destinations, when I go to fax I pressed clear al and it doesn't work?? I also do not know how to send a fax, I have the phone line connected but it comes back tx failure???
FIrstly, sending a fax : Make sure you have the telephone cable plugged into the correct socket in the back of the copier. There should be one for "LINE" and another for "PHONE" - make sure you are plugged into LINE. On the display panel go into fax mode (press the fax button) and then press the "monitor" key....you should hear a dial tone...this means your fax line is working. You should be able to just dial the number you want and press the start button..... unless you need to dial a 9 to access an outside line - dial that first. make sure the number you are dialing is valid.
To clear/delete email addresses : I assume you have email addresses setup in the address book and want to delete them?
Press "user functions" on the control panel and press "address" then press "address book" button. highlight the address you want to delete and press delete - then confirm deletion....and its gone!
Jan 21, 2010 | Toshiba e-STUDIO 352 Black and White...
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
How do you print out the fax address book on a Canon iR 2870
you have to print the address book from the address book section of additional functions
Apr 13, 2009 | Office Equipment & Supplies
How do I enter phone numbers into the address book for faxes
select (custom settings) then (address control)
then (diret address) its easy from this point
Mar 05, 2009 | Sharp AR-M455N Copier
Will not stop faxing the same document
There should be a memory clear procedure in the menu to stop that.
You will have to reenter the time date, your phone and business name once you clear the memory.
I dont have a book for that particular machine, but faxs do have a memory clear feature for lock ups like that.
Mar 05, 2008 | Panasonic PANAFAX UF-6000 Fax
Fax software
You can click without cover page when fax thru smart thru software.
Address book from computer is entirely different from the printer.No way you can open the address book in computer from your printer.
Feb 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Faxing from memory
I am not sure exactly what you are trying to do. Here is the internal Kyocera link for the user guide and fax quick list. Hope this helps they are down loadable PDF's.
http://www.kyoceramita.eu/content/sites/kme/eu/en/index/service/dlc.html?initial=false&search=any&searchTerm=FS-1118&category=#
Jan 05, 2008 | Kyocera KM-F650 Plain Paper Laser Fax
Canon imageRUNNER 4570 Copier Logo
90 people viewed this question
old marine
old marine
