Question about Kenwood VR-407 Receiver
Have a VR-407 receiver, all of a sudden there's no audio coming out of the speakers from the TV. Also, DVD, tuner and CD player have no sounds. Speakers are only a couple years old.
    Champion:
  • 287 Answers
Check for basic things like speakers being turned off or switched to speaker b from a and the tape monitor switch being on. Larry's Electronics.
Posted on Apr 28, 2010
  • TIMOTHY TAYLOR
    TIMOTHY TAYLOR Aug 11, 2014
    i did that and it still doesnt have any sound..it was playing and it just made the clickin sound like it does when you switch from a to b then was when it quit producing sound..THANKS FOR QUICK ANSWER LARRY,,,TIM
  • Larry Stiles
    Larry Stiles Aug 11, 2014
    see if it will stay n with speakes disconnected just running into headphones.
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
No sound from tuner all other inputs OK
It sounds as though one or more of the MOSFET's failed. MOSFET's are metal-oxide semiconductor field effect transistors. In layman's terms the Ic responsible for amplifying the sound produced in a given circuit.
These are not difficult to replace for a qualified shop and I think you would be surprised at how inexpensive it actually is - for a qualified shop...
My advice send it in and have it estimated and repaired. You might even research the net and send it off to have it done... Stereo repair is a very competitive market and it could save you some real bucks..
Hope this helps
Bill
Nov 14, 2007 | Kenwood VR-407 Receiver
I have a VR-407 reciever and I am unable to get my CD/DVD rear outputs to work. I am hooking up a DP-3020 and I can get it to work in the Audio L/R jacks in the front. Is there something that I need to do...
A Kenwood VR-407 is a receiver and has an INPUT pair for CD/DVD, not outputs. Plug ANY functioning audio source (except a turntable) into it and select it on the front panel.
If your DP doesn't work on either I'd suspect something is wrong with IT.
May 24, 2011 | Kenwood VR-407 Receiver
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
Right speaker not working. Will work during test however is not working after.
When it works with only the audio test signal that is provided by the receiver and nothing else, then that indicates that the device that is connected to it that you are trying to get sound from is not functioning properly.
First however, make sure that your balance controls are properly adjusted for matched output. Then check the connection of the devices such as your DVD player, CD player etc. If you are using digital connections such as optical or coaxial, then try a different cord...they might be damaged.
Feb 12, 2010 | Kenwood VR-407 Receiver
I have a Kenwood VR-407. TV and Blue-ray are
Check the manual for "Volume offset" at the input mode. I'll pull the pdf on the unit, If I find it, I will send the instructions. Hope this helps
Dec 23, 2009 | Kenwood VR-407 Receiver
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
Hi, i have a kenwood VR-407 and can't get audio..
You haven't really given any details as to your connections. This would help greatly in troubleshooting I am currently using my TV and DVD trhough my VR-407 with no problems. so.....
More info please :)
Mar 07, 2009 | Kenwood VR-407 Receiver
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Dec 14, 2007 | Kenwood VR-507 Receiver
Speakers not working
They will only have ambient sound (not same sounds as front speakers). Also for each input (video 1, video 2, dvd, tuner, etc...) you need to choose what surround mode you would like to use via the "Listen Mode" button. There is a little pictogram in the display which indicates which speakers are in use.
Sep 12, 2007 | Arcam AVR-200 Receiver
Kenwood VR-407 Receiver Logo
500 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
