Question about JVC TH-M505 System
Speakers 3 of the five speakers are not working is this a big problem or something I can try at home and check by removing the back cover. (some kind of test)
  • 682 Answers
Befor go deeper check your cable first -take the cable from the good one and test the three bad speakers with it-if no good result the problem is in the speaker itself or in the system-test bad speaker with good cable in the place of good speaker if it is working the problem in your system output itself not the speaker.do this for the other two speakers
Posted on Apr 06, 2008
My rear speakers/subwoofers aren't working in my 2001 Buick Century. How do I fix them?
check to make sure the fade button or know is set to the middle so that all 4 speakers should function normally. If they are still not playing you can disconnect the speaker and try to test it on something else. If you can get long speaker wire try connecting it to a home stereo or something like that just as a test.
If they work the problem is not your speakers, its either in the wires connected to the stereo or the head unit itself.
Good Luck
Oct 18, 2013 | Car Audio & Video
Sub connected center speaker does not work
hmmm..that's a little weird..does the sub work on it's own? Is it powered? is it connected to right boost terminals ?
Feb 29, 2008 | Yamaha DVX-S100 System
I have no sound on my tv
check if the volume control is set at minimal or the sound is set at mute... if its under warranty just bring that to the store or to the authorized service center. if not try this simple steps... (1) unplug the unit from the wall socket (2) place the unit on a flat surface. make sure not to touch the screen. (3) unscrew to remove the protected cover (4) look at the speaker. check if its properly connected. check if the speaker is not busted or open by testing the speaker. (5) if you have an ohm meter just place the test prod on the speaker terminal. it should read 8 ohms or what ohms the speaker is specified. if you don't have a ohm meter try to use a 1.5 volts double AA or triple AAA type battery.but first remove the connection of the speaker so that you will not damage the unit.. using a battery place the positive side to one side of the speaker terminal. use a piece of wire to connect the other side of the battery to the one side of the speaker. once you place, you should hear a crackling sounds... if not the speaker is the problem. (6) replace the speaker. and connect it back from the terminal. (7) place the protected cover back to its original position. (7) turn the unit on and enjoy.... ty
Jun 23, 2011 | Philips Televison & Video
Speaker
Is may have cut the vioice coil. In this case it might be replaced (the voice coil inside the speaker) by a technician (it depends on your area, since there no many left). Just in case the problem isn't so big, open the box (usually unscrew the scews around the speaker) and try to locate the 2 cables at the speaker. Are they connected firmly at the speaker's connectors or anyone is gone? In case you can use a multimeter, it's a good idea to measure (at ohm scale) the speaker itself (disconected from the cables). If you have no reading the voice coil is cut-off. A good reading is something between 3-12Ohms.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 13, 2010 | LG HT303SU Theater System
How do I remove the speaker cover on the front doors of a 96 corolla? The cover is part of the door handle and storage box. I don't see any screws to remove.
Generally speaker covers are snapped in with spring clips to hold them in place. Using a screwdriver or something to pry with - Put a rag or roll of paper under the screwdriver and gently try to pop off the cover. I suggest prying from the bottom so and scratched won't be visible. To reinstall - just press it back into place. If it is the kind that just has holes drilled through the panel it will not come off.
Jan 16, 2010 | 1996 Toyota Corolla
No sound
Try a reload, occasionally a conflict of shared files knocks it out.
Jan 07, 2010 | Microsoft Windows XP Home Edition
JBL Creature Speakers
I fixed a similar problem I was having. It requires a little work.
Take out the four screws from under the broken speaker. Carefully remove the cover, separating the speaker from the base. The two are wired together so don't pull them apart with force. Then remove the single screw, which is much larger the the previous four, and separate the speaker from the top cover.
If you chose you can remove the wires from the speaker, they just snap on, but its not required.
What I found is the speaker issue is not with the wire or the power, but the speaker it's self. On the back there is a big round metal piece. On my speaker that piece was pushed towards the front of the speaker. When I looked at the good speaker, that big piece was all the way back. So I simply pulled it back and presto, instant fix!
I hope this works for you.
Dec 09, 2009 | JBL CREATURE II Computer Speakers
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Companion 3 were plugged to 220v instead of 110v. What can i do??
alot of speakers have some kind of glue or epoxy, so if the screws vibrate out the glue will hold it together. you may have to pry the panel off. hope this helps! good-luck, glen.
Aug 01, 2008 | Bose Companion 3 Computer Speakers
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
JVC TH-M505 System Logo
115 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
