I just had a 2 stage furnace put in and a 1 stage thermostat. The thermostat has been changed three times, but the furnace still won't come on as it's programmed to do. Where do you think the problem lies?
  • Robert Moller
    Robert Moller May 11, 2010
    Why a single stage thermostat on a two stage unit ?
  • laura Newman May 11, 2010
    Make and Model of the furnace and thermostat?
    Novelist:
  • 135 Answers
A single stage thermostat can be used on a two stage furnace, but there is a dip switch on the furnace computer board that will need to be changed, the directions are in the installers installation guide.
Also not knowing what type and brand of thermostat you have, leaves me guessing, some higher end thermostats have intelligent recovery, if you set it to 70 degrees, at 7 AM, it will try to have the temp to 70 by 7AM, so it could be coming on, even 2 to 3 hours early, depending on the temp. Most of them have a 7 day curve, so it takes awhile for them to adjust, this feature can be turned off, you will again need the installer's install manual.
I hope this has helped, please rate me and also get back to me if you have any more questions.
Sincerely,
Paul Gibson
Posted on May 01, 2010
Can I install this thermostat to a Geo Thermo Premier 2 Water Furnace with the following wires connected as follows from old Honeywell thermostat TA511M1010? Old connection; R, C, Y1, W, Y2, L, O, G
Yep, you should be able to run your water furnace with the thermostat. Just wire it up same letter to same letter on both devices. If your thermostat worked before, it should work again. I couldn't find the honeywell part you listed, but the terminal designations tell enough on their own. Don't forget to shut off all power sources before doing any wiring, and to configure the control board on the water furnace before switching the thermostat to any active mode.
In case you don't have it, here's the install guide3 for the water furnace.
http://www.waterfurnace.com/literature/premier/IM1555.PDF
Please mark me helpful and feel free to ask more questions in this same thread if you need to.
Jan 03, 2015 | Honeywell Heating & Cooling
Just purchased this heater, the fan comes on but the heat is next to nothing. I checked the voltage at the elements and is is 235v the amperage on L1 and L2 is 20.8a. If I pull the fan wire off the relay,...
First off, 20.8 amps is approximately the amperage draw on a single element furnace (nominally 5 kw.) So if you have 3 or 4 elements, (15 or 20 kw capacity) the problem is the remaining elements are not being enrgized. Look to see if there is a W1 and W2 and even possibly a W3 terminal on the terminal strip. If so, and its not a heat pump, there should be thermostat wires on all three, indicating three stages of heat. To energize those properly, the thermostat should be a multi-stage heating thermostat providing W1 and W2 at the minimum. If you do not have a multi stage thermostat, and there are no wires on W2 and W3, jumper W1, W2 and W3 together and the furnace will come on at full capacity with the single stage thermostat.
If you DO in fact have wires on the additional W terminals, you more than likely have a heat sequencer that is not energizing the 2nd and possibly the third stage of heat. A three element furnace is typically called a 15kw furnace and the three elements should draw approximately 19 to 20 amps each. So when each stage draws in, the clamp on amprobe on the main incoming wires will correspondingly increase with each stage.
Also, some 15 and 20 kw furnaces require two circuits to supply the elements, and I have been on calls before where the second breaker was not turned on, and in one case, the second circuit wasn't even wired in from the electrical panel box.
DO NOT pull the wire off the fan while the heaters are energized as they will rapidly cycle on an overtemp device. Some actually have a "one time" thermal link that once melted render the respective element inoperable until that thermal link is replaced. They will melt very easily. An energized element MUST have airflow across it !!!
Dec 13, 2014 | Ouellet 5000-Watt Utility/Garage Space...
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
Nov 23, 2013 | Source1 CTS Series Model S1-THPU32P7S...
How do I troubleshoot a goodman 2 stage that always starts at high stage
It wouldn't be stuck if that's the case the valve would never shut off. Sometimes those 2 stage heat thermostats stats call for 2nd stage if the room temp drops more than 2 degrees. Easiest way to check is take the w2 wire off of the tstat and try a call for heat. If the furnace kicks on both 1& 2 stages then its either your wiring on the fan board or a dip switch setting. If it kicks on 1stage then it's your thermostat.
Mar 19, 2013 | Heating & Cooling
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
I am trying to install a thermostat and I am not sure where to put all the wires... it is for american standard freedom 90 two stage - furnace and air conditioning
Should be like this:
Y from furnace goes to Y on thermostat (yellow)
C from furnace goes to C on thermostat (usually blue)
G from furnace goes to G on thermostat (green)
W1 (first stage heat) to w1 on thermostat(white)
w2 (second stage heat) to w2 on thermostat (black)
Doesn't sound like you have a heat pump but if you do "o" will also have to be connected which is the reversing valve.
Jun 21, 2011 | Heating & Cooling
I have two heatpumps up and downstairs and two furnaces (piigy back). At times my pump outside freezes up and cold air blows in the house. I was told that I needed a kit to tell my furnace to turn on when...
A couple of things... First your furnace should be 2nd stage on a 2 stage thermostat and if the heat pump don't keep up your furnace should be coming on anyway...If you get a Honeywell Vision Pro 8000 series thermostat for 2 stage heat pump operation and an outdoor sensor, you can have the thermostat shut down the heat pump and start the furnace at what ever temperature you decide...
Secondly, you have a problem with the defrost cycle on your heat pump(s) If they are frosting up that bad at 40 degrees than the defrost is not working on them. If they are hookup up right, every fours hours or so they will go into A/C mode and heat the oudoor coil up to melt the ice off of them. The furnace should be heating while that is happening. Sounds like they really don't know what they are doing when it comes to heat pumps...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 16, 2009 | Heating & Cooling
I have a honeywell thermostat model # th5220d1003-0636 & need to know what connections to make for gas forced air heat.
This is a Focus Pro 2 heat,2 cool thermostat. If you are connecting this to a single stage(1 heat) residential furnace then your connections are: At the thermostat the R and Rc therminals are internally connected so you can connect your R terminal wire from the furnace to the R terminal at the thermostat(this is your 24 volt supply for both heating and cooling. The W or W1 wire (heating) from your furnace you connect to the W1 terminal at the thermostat. The W2 wire from your furnace(if your furnace is a 2 stage furnace) you connect to the W2 terminal at the thermostat. The G wire from your furnace(indoor fan) you connect to the G terminal at the thermostat. The Y1 wire(cooling) from your furnace you connect to the Y1 terminal at the thermostat. The C wire(common or neutral) from the furnace you connect to the C terminal at the thermostat.
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
Furnace runs but once it gets to teamature it does not shut off but goes in and out of stages
Disconnect the thermostat wires from the circuit board. Tape door switch closed. Put a jumper on R and W on the circuit board. Let the heater run for about 5 min. Disconnect the jumper, furnace should shut down. If it continues to run you have a bad board. When you reconnect the thermostat, look for a shorted wire or a bad thermostat. I suspect a bad board if the furnace is hunting thru the stages.
Nov 03, 2009 | Goodman GMS90703BXA Heater
A/C blows fuse on call for 2nd stage.
my guess would be a problem with the low voltage wiring a short have it checked out by an electrician
Jun 21, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
