Question about Minolta magicolor 2400W Laser Printer
Minolta 2400W errors
Minolta 2400W color laser - was getting replace Magenta error - toner out - error varied. I swapped chips - no change. I removed all cartridges, cleaned all contacts on and off cart, and vacuumed printer.
Now I get a install Cyan error in status and normal flash error/no ready. Swapped yellow and Cyan and still get same error. All contacts - I am aware of - are cleaned. ALSO external ROTATE button doesn't function.
All cart appear properly inserted. Carts have been refilled 2-3 times. Functional for some time after last refill.
ideas?? answers??
  • Minolta Master
  • 6,680 Answers
GO and get 4 Konicminolta image units one for each color and replace them do not use third party. NEVER ever use a vacuum cleaner the static electricity can cause sensors to go bad !!!!!!!!!!!! might have destroyed the chips on the image units SO recommend get all new hopefully you did not destroy the control board with static electricity
Posted on Mar 01, 2015
  • 214 Answers
SOURCE: Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
Posted on Jun 19, 2008
SOURCE: Error flashing, Status 'Put Cyan Toner' - but toner showing 100%
Order a new "Button", the small part that has 3 contacts that touch each cartridge as they rotate by. It is a small black switch that can be easily accessed by removing all cartridges. It pops out easily, be carefuld not to damage the wires that attach to it. You may find the part at: https://www.nationalparts.com/store/cart/purchase1.asp?pid=6984&XPR=0666058409690586098F076D0B0666058409690589098C076B0B
There is a min. $15.00 charge, so buy 3 of them at $5.00 each, plus shipping, you will spend $28.22 (ground shipping). Works for me!
Posted on Jul 13, 2008
  • 12 Answers
SOURCE: cartridge not installed message
This worked for me
Each toner cartridge has a small green chip with 3 gold-colored contacts on it. First thing to try is to rub those contacts with an ordinary pencil eraser. You will need to rotate the toner carousel to get to all 4 sets of them. To get it to rotate, there is a little square-ish hole in the white plastic housing to the right of the toner cartridge that is visible when the top cover is raised. Push a pen down in the hole, which will push on a tab allowing you to rotate the toner carousel until you can see the next cartridge. Repeat for all four toner cartridges. Close up the printer, power it up, and see if it solves the problem. If not, do this: Remove the drum (gently pull on the green handle). Be careful not to touch the roller or let it contact anything. Get a flashlight, look down inside the printer on the right (it's kind of hard to see, it's almost under the toner cartridge). You will see a black sensor switch with three wire-like contacts, surrounded by a square white housing. Wipe off those contacts, if you can get the eraser in there better yet. Contacts are kind of flimsy, be VERY careful you do not bend them. Next, take the point of a pencil and push on each contact, it should move in and return when released. If that seems good, put it all back together and try the printer again.
Posted on Sep 03, 2008
  • 9 Answers
SOURCE: QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
Posted on May 25, 2009
  • 5 Answers
SOURCE: The ERROR light of my Minolta magicolor 2400W
Try to open the blue cover and close it. Then press a few times the "rotate toner" button. After that powerswitch off and on, should run.
If it´s don´t worked, make sure you have every transport secure away from the cartridges.
The contact`s should be clean in Printer and on cartridges.
If still the same prob, start from first tip.
It´s worked by my 2400W feed new toner.
Posted on Dec 13, 2009
When I start up printer after it rotates the toner cartridges the error light comes on and cannot be cleared . On my Windows computer it says there is no cyan toner cartridge. There is, of course.
Does it say Image Cartridge or toner. Is the cartridge third party if so replace with a real Minolta cart the machine do know info on the chip on the cartridge and reject them sometimes
Feb 19, 2011 | Minolta magicolor 2400W Laser Printer
How to deactivate toner colour errors?
if any toner ends in a printer, then replace it.otherwise error will show continuously.
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
Error light
What kind of error....blinking light which lights are blinking..or is it a code 17h or something like that.....please clarify for me. thank you....whytfang. In the mean time you might take all of the cartridges out and make sure they are in correctly and none are damaged...and then clean the circuit boards and the reading board under the cartridges, then reinstall them and turn the printer back on...if not fixed try again and take care with the reading board...it is delicate...and the chips should be blown clean with pressurized air...like the canned spray used to clean keyboards or other delicate computer components. Try this in the meantime and send me the other info...good luck.
Jan 28, 2009 | Konica Minolta magicolor 2400 Laser...
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Error
The only way to reset the toner error is to replace the counter chip on the toner cartridge. These should go for about $10 a piece. Otherwise, you can set the engine to continue on error, and ignore the blinking light. Better yet, I put a piece of electrical tape over it. You can still read the status on the LED's, but not have your wife complain about it. Saves you $40.
Dec 20, 2008 | Konica Minolta magicolor 2400 Laser...
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Error 2408
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Jul 11, 2008 | Konica Minolta magicolor 2430 DL Laser...
Hello
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Toner problems
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
Apr 07, 2007 | Konica Minolta magicolor 2300DL Laser...
Minolta magicolor 2400W Laser Printer Logo
123 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
