Question about GPS
I REPLACE THE BATTERY IN A MIO C 520. THE BATTERY CHARGES UO, BUT THE INSTRUMENT WON'T TURN ON
  • Paul Alony Apr 27, 2010
    I feel a click when pressing the on button,
    so I dont believe that this is the problem
    President:
  • 1,194 Answers
Thanks for using Fixya.
Press & hold power button for 10 Seconds and you should see the device power up.
If your device is still not turning on then your device need service (repair)
Good Luck & Have a nice day.
Posted on Apr 27, 2010
  • 2,973 Answers
May be suffering from either of the two faults.
1. The power switch may have concked out. Replace it.
2. The connections from the battery may be out. This is unlikely as the battery is charging, as you say. So, the suspicion goes to the power switch.
  • Rinoo Kumari Apr 27, 2010
    Could it be the switch's click? If not, then it could very well be the connection from the battery to the PCB. The charging circuit is fine. It is the battery out. Generally the battery out is connected to the PCB through a connector. Just unplug it and re plug it.
Where is the battery on yamaha mio 125 gtx
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
mio 125 gtx battery location Google Search
Scooter Troubleshooting Scooter won start All about Scooters
Yamaha Mio Service Manual
OEM parts for Yamaha
http://www.ironfurnacecwma.org/manual/manual-user-yamaha-mio.pdf
Jun 01, 2014 | 2000 Yamaha TW 125
Can't start my mio soul
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Mio won Start
Mio Wont Start In The Morning
http://www.rasterline.com/MIO%20SERVICE%20MANUAL.pdf
Yahaha MIO soul owner manual
Sep 14, 2012 | Yamaha Motorcycles
Cannot pair my nokia N6730c with plantronics voyager 520
You want to remember that newer phones are like small computers, so
they may become corrupt over time and you may need to reset them every
so often. Simply turn your phone off and remove again the battery for
a few seconds, then replace the battery and turn it back
on again. Then carefully follow the pairing instructions in the attached link.
Plantronics Voyager 520 User's Guide
Good luck from Headsets Direct!
May 29, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Need to replace the battery in my Mio MOOV 300 GPS how can I do it.
If you go here:- to the Mio Moov Site they can sell batteries and or install it for you if u are unsure, i had the same problem myself and just fixed it.
FITS: Mio Moov 300
CAPACITY: 750mAh
REF PART #: CS-MIV300SL,0781417XCPRICE: $45.00
Click Here for the Mitac Mio Battery Center Moove 300
If You do not want to install it yourself, Mail-In-Service is available for only $10.00 more. Use this link to order the mail-in-repair service (including parts and labor) rather than just the part :
Jul 25, 2010 | SNK Mio Moov 300 GPS Receiver
Mio C320 - How to replace battery indicator?
c230.files.wordpress.com/2008/02/battery-replacement-on-the-mio-c-230.pdf
go to that link and download the dpf and it'll explain everything
Feb 10, 2009 | Mitac Mio C320 Car GPS Receiver
Mio p550
I dont know about the charges but did you "format" the card?
Jul 01, 2007 | Mitac Mio P550 GPS Receiver
Mitac mio 168 won't turn on
ITS THE BATTERY MANY ON EBAY :)
Jan 30, 2007 | Mitac Mio 168 Pocket PC
Mitac mio 168 digiwalker
Hi, to replace battery, you need to undo the 4 screws hold the back casing. When these are removed you can open the back, revealing the battery. There is a black plug that pushes into a white socket on the pcb, with 4 wires coming out of it that goes to the battery. Pull this plug out and the battery then comes free. Hope this helps.
Jan 16, 2007 | Mitac Mio 168 Pocket PC
GPS Logo
22 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
