Question about Kitchen Ranges
Kitchenaid Oven works great but won't turn off
The oven continues to work perfectly except for one thing.
The oven will not turn off until we throw the breaker.
The oven will work perfectly again but not shut off, etc., etc.
Bad CRC? How difficult to replace?
  • 3 more comments
  • livorno Dec 11, 2008
    Lower oven will not turn off. When you turn off at the breaker the service techs cannot replicate the issue, and therefore report "No Problem". My oven has been on for nearly 24 hours now waiting for the new service company to arrive so they can see the issue live. Everyone expects to see an error code, but none is shown. yet the oven is clearly on maintaining a temp of approx 300 degrees.
  • Anonymous Jan 25, 2009
    exactly as described above
  • Anonymous Mar 02, 2009
    same problem, any solutions
  • aehug Mar 24, 2009
    Same as above. We turn the oven off and it stays on. We have to keep starting and stoppiing over 30 minutes or so and eventually the off button works. Temp stays at 350. Any solutions?
  • Anonymous Apr 08, 2009
    SAme here too. Oven wont shut down, nor does the timer button work. Everything tourns on OK, opperates as it should, but wont shut off. We turn the temp as low as it will go, when it cools down, it will shut off then.
  • 31 Answers
Replace the touch pad.
Posted on Mar 04, 2010
Pad on oven does not work cant start oven
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts -
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
KitchenAid gas convection oven model # kgst307hbl4 won't turn off
seems like the safety switch not work. be careful
Mar 27, 2017 | Ovens
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JT955 GE Profile 30"double oven...when the food is cooked, and I press "clear/Off", the oven won't shut off...continues to maintain temperature? Tonight, I had to shut it off,...
Your wall oven has two main components that control the oven. The main control computer and the user interface. Your problem is probably in the user interface, although it could be the main control or both. I have had some success cleaning the ribbon that connects the user interface to the control with a little rubbing alcohol. That only works some of the time though. Due to the fact that the oven works except for the cancel button I would lean towards replacing the user interface if cleaning the ribbon dose not work.
Aug 29, 2011 | GE Profile JK955SFSS Electric Double Oven
Will not turn on says door
There are 3 door switches arond the door that can throw up this error but if the 2 fuses are blown also it will throw up this error. You can ohm out any of the fuses or even the door switches but until you repair them it wont work. I have even found both fuses to be blown. If you are nervous about pulling apart your stove make sure whoever does is very familiar with this line of Kitchenaid. Hopefully this helps.
Jan 30, 2010 | KitchenAid KBMC140H Convection Microwave...
How do I use the thermometer in my Kitchenaid Superba?
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is:
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
Dec 05, 2009 | KitchenAid Architect Series KEBC107KSS...
KitchenAid KERA807PSS01 oven won't shut off until breaker thrown
assuming its a stainless stell oven? if so heres the par tyou need its a membrane switch( your cancel button ceased to operate corrrect???not a bad part to install you need to remove a few screws from under control panel itself( perhaps a few on the sides, the front control will lift off and this part is installed from behind the control panel (SHUT THE BREAKER(S))
part number 9756595ES
in the mean time instead of shuttin off the breaker toreset you can simply( requires reading manual ) set your oven to time bake. it will shut off automatically after predetermined time has been obtained.
Apr 27, 2008 | Ovens
Kitchenaid Oven KERA807PSS01
perhaps you would like to visit this site and read what others have to say about it.
It's not pretty.
Apr 06, 2008 | Ovens
Kitchen Ranges Logo
1,080 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
