Question about Craftsman 25cc Gas Line Trimmer
Engine does not acelerate , only runs in start then it chokes,
  • Craftsman Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
Cold choke baffle has 3/16 opening minute I pump accelerator choke thermostat closes primary baffle shut no air to start I force choke open to start why insufficient air to run at high idle?
Your engine probably has an automatic choke device that adjusts automatically with engine temperature. To set the choke when the engine is cold you have to depress the accelerator to the floor and release it completely. You shouldn't have to depress the accelerator again to start the engine, turn the key the engine should start. As the engine begins to warm up it will also begin to initially run faster then it will start to run rough. At this point you have to press the accelerator and release it again. The auto choke mechanism should allow the choke butterfly to open. There may be a number of stops in the system and the choke butterfly will stop again still not fully open and only become fully open when the engine is at operating temperature. Hope this answers you question, Rgs. Bob
Jun 21, 2015 | Cars & Trucks
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Light Engen comes on
Pull up the error codes and post them here. Thanks.
Apr 09, 2014 | 2001 Toyota Corolla
CAR JERKING WHEN ACELERATING AND UNEVEN IDLING
the problem may be related to spark plugs,choked fuel filter,dis coil fault if this car is of petrol version.if it is of diesel then chk out diesel filter.injector may choke or improper fitting
Sep 17, 2013 | 2006 Kia Rio
Acts like the choke is stuck closed it won't stay started and runs ruff until engine warms up then its fine. What do i do?
Well the choke has an electric part that heats up and makes the choke open in a few minutes. As soon as the engine starts the choke should open about 25 percent by way of a vac pull-off.
You can take the air cleaner off and watch the choke while someone starts the engine cold. If the choke does not open after it starts, check the choke pull-off. You can also open the choke with a screwdriver to see if the engine clears up.
Jan 29, 2013 | 1987 Chevrolet Caprice
My beattle glx start light EPC. start engine but dont aceleration. I buy module (computer and configuration) but no aceleration.
new computer needs programming---------ask majicmech@aol.com-------pero primero hav u done tuneup on ignition and fuel -clean throttle body idle control
Dec 08, 2011 | 2001 Volkswagen Beetle
Only in morning i need to put gas in carb to start it and its geat for the rest of the day very little gas and fast to start
I would check the choke to see if it is close if not try ajusting it by losening the three screws on the right side of carb (passenger side car not running) hold acelerator left side open slitely turn black part of choke to the left till choke just closes release acelerato tighten the three scews if all that is ok check to see if by pressing acelerator with choke open if you see gas squirting (car not running)
Jun 21, 2011 | 1996 Chevrolet Blazer
When I acelerate my car wants to choke
I HAVE PERSONALLY CHANGED A FEW THROTTLE POSITON SENSORS IN THESE VEHICLES. BUT BEFORE YOU DO THAT, TRY SPRAYING SOME CARB AND CHOKE SPRAY IN THE THROTTLE BODY WHILE THE CAR IS RUNNING. YOU MAY HAVE TO HOLD IT AT A HIGH IDLE SO IT DOESN'T DIE ON YOU. THIS SHOULD HELP TO REMOVE THE CARBON IN THE THROTTLE BODY. IF IT STILL WANTS TO CHOKE, THEN CHANGE THE T.P.S. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
May 16, 2009 | 1999 Dodge Durango
Service engine soon light flashing on acceleration
When the service engine soon light is flashing there is a miss fire in the motor if you look in your owners manual it will tell you that.The same thing happend to me and it endid up to be the cat...
Mar 17, 2009 | 2002 Chevrolet TrailBlazer
Craftsman 25cc Gas Line Trimmer Logo
83 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
